Who Sells Big Reds?
How about big blacks off of a 928 GTS. These might be cheaper to locate. I just put a set on the track car, with 3.6 cryo rotors and it's really nice. If you buy new and use the 928 GTS rotor, you can do these for less than $750.
Originally Posted by aeronautica86
whats the difference between the big reds and big blacks? I've heard they are pretty much the same?
993TT/928GTS front calipers
Radial mount, these are commonly known as the Big Red and the Big Black. They are identical in all ways except for their color. 36/44mm pistons paired with a 322mm rotor. Each piston has a pressure seal and dust boot, readily available. 58mm tall pad. A number of rotors available, some requiring custom hats, others a direct fit. 928GTS rotors are a direct fit and non-drilled. 911 C2 3.6 Turbo rotors are a direct fit and drilled. 993TT rotors require custom hats and are 2-piece and drilled. Used values sit over $500 a pair.
Either upgrade requires a master cylinder upgrade to match. This is the only way to maintain track-worthy pedal. There are bolt-in ATE 23 as well as 25mm master cylinders available from other cars. Look at early-90s BMW 7-series for the 25mm, and mid-90s 911s for the 23mm.
Also, the bleed valve is in a different location between the big reds and big blacks. Big reds mount ahead of the wheel axle so the bleed valve would be trailing when installed and require a swap while big blacks run behind the axle and don't require any changes.
Raj
Raj
How about standard 250bhp (S) calipers? (reasonably big blacks) who sells those and how much? I am thinking of replacing mine they are 15 years old I have plate lift and could do with new external piston seals. Whilst they still work OK I am pretty confident new ones would be an improvement, If they are significantly cheaper than big reds/blacks that might be the way I go.
Tony
Tony
