tial + 15psi chips?
Would using a tial 38mm wastegate and autothority stg2 chips be a bad combo? I notice that the stock WG constantly leaks all the way up to full boost. I assume I will get faster spool up with a better WG. I just dont know if it will be a bad combo. These chips are temporary until I get some other things and upgrade a year or so from now.
Well, the midrange richness of the APE chips wouldnt bother me- but what I would be scared of is the APE chips are mapped for the stock wastegate (which will bleed off boost up top in the rev range) whereas the tial will hold ~15lbs all the way to redline - causing a lean condition.
I ran the same combo for about a year or two with no ill effects, but thats not to say I wasnt thinking about the possibility of a blown headgasket...
