Best way to hook up aftermarket oil pressure gauge
Old 11-07-2005, 05:25 PM
Musche
Musche's Avatar
Default Best way to hook up aftermarket oil pressure gauge
Looking to see how others have hooked up the sending units for an electric aftermarket oil pressure gauge. I want to keep the original sender so the original gauge still will work. I saw this on ebay and wondered if anyone else has used this method. Any thoughts or ideas are appreciated.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Old 11-08-2005, 09:16 AM
Musche
Musche's Avatar
Anyone?
Old 11-08-2005, 09:30 AM
jerome951
jerome951's Avatar
Really doubtful the item you linked to would fit between our block and oil filter.
Old 11-08-2005, 06:17 PM
dlgranison
dlgranison's Avatar
Here is a pic of what I have done to my car and many others too. I modify the stock sender and remote mount the sensors. The other pic is of my gauge panel that I just removed and will be selliing. I also modify the drain plug for temp. Hope this helps. You can email me and I can help anyone do this project
Derek
Old 11-08-2005, 06:35 PM
fast951
fast951's Avatar
dlgranison, very good idea. Did you make the block for the sensors, or you found it somewhere?
John
Email
www.vitesseracing.com
Old 11-08-2005, 07:29 PM
dlgranison
dlgranison's Avatar
The block is something I made. I do a bit of machining at work so it was easy. It is also rubber mounted to extend the life of the sensors. Autometer sensors do not like vibration
Old 11-08-2005, 07:42 PM
snappy
snappy's Avatar
Musche, why dont you purchase that and see if it works
I like the idea and think it might fit. clean solution.
Let us know how it goes.
I will probably look into getting one if it works out for you.
special tool
special tool's Avatar
Granison - VERY pretty.
Looks like something you might see on an IMSA car, or something like that.
Old 11-08-2005, 08:03 PM
dlgranison
dlgranison's Avatar
HAHA ST. yeah I got a few good ideas from those cars. You should see my driving lights and some of my other wiring projects
Old 11-08-2005, 09:19 PM
fast951
fast951's Avatar
dlgranison, if you are selling the block, I'll be interested in getting one. Please email me directly.
Old 11-09-2005, 04:17 PM
Musche
Musche's Avatar
Dl,
I like your idea. How did you run the braided line to the block? Where did you find the adapter to go into the fitting where the original gauge was located if that is where you tapped from?. I believe this is a M18 x 1.5 thread on my car but yours looks much smaller. I can make a block if I can find a tap this size but it is doubtful.
Old 11-09-2005, 04:40 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
That adapter on ebay is similar to what i use, i use a Greddy adapter (thnak you chris) and hooked up both oil pressure and temp sensors there.
Don't do anything with the oil drian plug, it has a magnetic tip which helps out tremendously:
Taken from here: https://rennlist.com/forums/924-931-944-951-968-forum/236587-here-s-one-for-the-wtf-files.html
Old 11-09-2005, 05:07 PM
Musche
Musche's Avatar
YIKES! That's scary...looks like one of the bolts on the plastic windage tray. Right now I'm only looking for a pressure connection so the drain plug is not an option. I always inspect my plug for bits and pieces as well.
Old 11-09-2005, 05:11 PM
Musche
Musche's Avatar
By the way hosrom, is that the pn#12002801 $68.00 item on their website?
Old 11-09-2005, 06:52 PM
hosrom_951
hosrom_951's Avatar
Yes Musche, that's the one, except i got it for around $47 from the Greddy dealer locally.
The oil filter does sit higher however, but just slightly higher. It makes changing the oil filter easier as well (it is not so deep in there).
Quick Reply: Best way to hook up aftermarket oil pressure gauge
