P O R S C H E 944 GTR TURBO Info Thread
Old 04-17-2013, 11:29 PM
  #136
tomjshore
tomjshore's Avatar
Default pics
cant seem to post any pictures?
Old 04-18-2013, 05:08 PM
  #137
peter mik
Cruisin'
peter mik's Avatar
Could you mail me? peter (at) pro-motor.dk
Regards
Peter
Old 04-18-2013, 05:12 PM
  #138
peter mik
Cruisin'
peter mik's Avatar
Hi Duke
I understand but what i wnat to know is if there should be no inner fender like your car or i should be closed seen from the back of the car
Old 04-18-2013, 05:29 PM
  #139
333pg333
333pg333's Avatar
Peter,
You could tub it off so the wheel is completely enclosed from the inside of the car and air doesn't get through the back of the panel. This would be quite normal, however, if you look at many modern racecars now they have much of the rear section behind the wheel open or even cut away completely. This would be to release pressure build up. The only thing is that you'd need to be aware of rubber and stones etc flinging up into the panel work. So perhaps half tub it or put screen mesh in there?
Old 04-18-2013, 08:47 PM
  #140
tomjshore
tomjshore's Avatar
Here are a couple
Old 04-24-2013, 03:18 AM
  #141
peter mik
Cruisin'
peter mik's Avatar
Thanks for pics and comments. I think I'll try with inner fender and see how it Works as if i choose to use half inner i'll have to make something to close it from the inside. Else Things will be flying to the inside of the car. Wonder how they did in the past?
Old 04-24-2013, 05:06 AM
  #142
Duke
Duke's Avatar
For the best aerodynamics you should leave it completely open towards the rear.
Old 04-24-2013, 05:56 AM
  #143
peter mik
Cruisin'
peter mik's Avatar
Ok. How have you closed the opening to the inside of car?
Old 04-24-2013, 05:57 AM
  #144
peter mik
Cruisin'
peter mik's Avatar
Maby You have some pics to share
Old 04-24-2013, 06:50 AM
  #145
333pg333
333pg333's Avatar
You can tub the inside possibly even with the stock inners? Not sure, if not, just get someone to fab up some alu liners that will seal off the inside of the car and leave the rest open. See how the modern RSR has half the rear of the wheel arch completely open to atmosphere.
Old 04-24-2013, 11:52 AM
  #146
Duke
Duke's Avatar
Here you go Peter
Old 04-24-2013, 06:36 PM
  #147
peter mik
Cruisin'
peter mik's Avatar
Can anybody tell me how to ad Pictures? Then i'll upload some pics of what i've come up with right now
Old 04-24-2013, 06:44 PM
  #148
peter mik
Cruisin'
peter mik's Avatar
And another question. What size and offset was used on these cars? I will be using the original 951 rear axle ( according to the Width ) of course with uniballs and so on. As I can see now the car will be 80 mm wider each side (160 mm total ) wich means offset below 0. Any ideas where to get a setup of rims i can afford
Old 04-24-2013, 08:52 PM
  #149
333pg333
333pg333's Avatar
You need to join Rennlist and become a member. It's only something like $25 per year and there's always enough in here to warrant that small cost.
Tony G is selling some good wheels here. https://rennlist.com/forums/944-turb...ck-wheels.html
Wide 3 piece wheels & cheap aren't often associated in the same sentence. The advantage of a 3 piece wheel is you can modify it to fit your needs.
Old 04-26-2013, 02:18 PM
  #150
Peedster
Peedster's Avatar
Some pictures of the Boss car...
http://www.history-of-cars.com/image...lemans-116.jpg
http://www.history-of-cars.com/image...-lemans-18.jpg
924 GTR engine the flux capasitor...
http://img.photobucket.com/albums/v1...raGTRmotor.jpg
Quick Reply: P O R S C H E 944 GTR TURBO Info Thread
