Too much hp-talk, let's talk real life numbers!
#151
It is illegal to run at those speeds in the US. If I could find somewhere off road I would most definitely get in on this challenge. Think of it this way. Most of you guys don't go on the dyno because there is not one in close proximity to you. But if there was. You would be there. Plus it's much easier to fib about the data collected without a second entity or standard testing device.
#152
Originally Posted by 951Obsession
interesting that like, 20% of people that post on this thread actually post numbers, and instead make up bull**** about how "there's no real way to do it" or how someone's measuring is flawed.
Ditto what Jimbo said.............and I would add that this is one notch away from bench racing.
#153
UAE Rennlist Ambassador
And for those using manual boost controllers, it is amazing since you go WOT on 4th gear to set the boost (hitting those speeds and higher) and yet you don't carry this test........
It's okay.........the track and empty airfields are also dangerous
#154
Quote: It's okay.........the track and empty airfields are also dangerous.
Yes! Dangerous to yourself but not others. I have driven in europe many times. The posted speed limit was 80k but everybody was over well over 120k. It's not like that here. We actually have enforcement. The congestion is also an issue.
#155
"Yes! Dangerous to yourself but not others. I have driven in europe many times. The posted speed limit was 80k but everybody was over well over 120k. It's not like that here. We actually have enforcement. The congestion is also an issue."
Well said. In addition, any idiot can get a driver's license here, and it takes more than failing to move into the right lane to lose one. They are cheap, and the fines minimal when compared to Europe. Ther just isn't the same appreciation for competent, and safe driving here. We're also vere litigious, so an airport won't let us come run there, due to threat of lawsuits. SUX!
#156
Mexican Ambassador
#157
Then why do you guys go for more power?
You guys are talking as if you bought Ferrari's, yet drive them like Camry's or something
You never set the boost before with MBC? never went above the speed limit in the 951? for tuning/fun reasons?
" the thread was supposed to be about posting numbers"
Well said.......having 1000hp is nothing if you can't use them right?
Dyno's give you numbers........the way the car reacts to real world conditions is completely different.
#158
Sorry I think I must've missed this through all the bickering, finger pointing, etc. But was it ever decided if this was rolling through (WOT) the 100km/h mark or from a steady pace and hitting it?
Not that I have a car that can do this anyway.
#159
Mike: All my numbers were done from a steady pace of 100kpr (62mph), never tried it from a roll (accelerating from 1st, 2nd etc...)
#160
Might be eaiser for more people to do a 4000-6000 RPM 3rd gear pull, WOT at 3000 then start time at 4000 rpm. Konstantin has posted some times like this in the past.
#161
Mexican Ambassador
i believe it was supposed to be roll on from 80km, start the clock at 100 like david said. i did it like that, and from a steady pace, numbers didnt differentiate much, not much as in, not like a whole second.
#163
Mexican Ambassador
Originally Posted by toddk911
I always thought, as in the 60-100mph, it was to hold at the given speed, then go WOT.
then again, i guess the best way to get a real calculated MPH is having the police run a radar gun on you.....but they dont like to do that without issuing you a ticket......
#164
Something to compare our numbers too.
If you happen to run across one of these, best give some respect
http://www.ultimacars.com/index.htm
Ultima Sports Ltd. sets world beating, certified performance records for road cars
with American Speed 377 c.i. Chevy engine.
0-60 2.7 sec.
0-100 5.5 sec.
0-150 11.8 sec.
30-70 2.0 sec.
0-100-0 10.3 sec.
1/4 mile 10.5 sec. @140 mph
top speed 231 mph (gearing limited)
0-60 2.7 sec.
0-100 5.5 sec.
0-150 11.8 sec.
30-70 2.0 sec.
0-100-0 10.3 sec.
#165
According to that post you have the fastest 2.5 liter 951 for now, at least from 100-200 its the fastest. Its 0.1 second slower then Enzo and 0.2 second faster than Carrera GT. Can you tell us what is you engine spec? You are still running 2.5 liter and GT30R (some sort of). Have you reduced the weight of the car?
Did a new run at sunday two days ago. Temp was 48 F compared to 68 at my 7,3 seconds run.
New time: 7,1 seconds
Im happy
Im happy
