Joint ball rebuild - whats up with mine?
Hey!
Look at these pictures! Is this how it should look like? I was going to do a rebuild, but couldnt get everything out! I got the buttom clip and plate, but after that nothing will come out! There wasn`t even a spring under there, like it should.
This is how it look likes and all the parts I took away so far:
Please help! Is this an aftermarket joint ball? Why cant I get everything out? Even tried to hammer a littlebit at the jointball to get everything out, nothing happenings.
Not rebuildable.
Someone has put a press-in bearing ballset in there when it was rebuilt last time.
You need a new a-arm, or one that hasn't been f'd up in this manner and is rebuildable, sorry for the bad news.
Interesting, I've never seen this pressed in ball joint done. If you plan to scrap the arm, why not press out the old one and see what damage has been done - let us know what you find...Bruce
Black Beauty:
My car had exactly the same thing made to the control arm. TRW 120 ball joint pressed into machined slot in control arm. I was a bit suprised to see this when I was trying to rebuild the arm with Rennbay rebuild kit My car was originally used in Sweden, so maybe some workshop in Sweden does these things? Do you know who/where your car was serviced in past?
I think your options are either get new "TRW 120" and press it in there (not safe in my opinion) or scrap the arm and get a new or rebuild one.
Good luck
Good luck
When purchasing "rebuilt" a-arms from the likes of Mid-America and Performance, this is what you normally get.
Oh no! Thats bad! A new arm cost to much.. Well, I guess I dont have any oppertunity! :P
My car has been in Norway for the last 7 years, and was imported from Germany before that. Dont really know who has been doing that rebuild to the a-arm.. Could sandèn in Sweden do that? Never mind, I`ll put it back together and get a new one in the winter.
tifosiman: is this normally a good rebuild? Does these joints often go bad, or should it hold for a long time?
As far as longevity of the pressed in joints, I don't know. I can tell you that when I purchased my car, in the stack of receipts was a receipt for a "rebuilt" right a-arm purchase and install about 2 years before I bought it (which was about 6000 miles prior). I put about another 4500 miles on it in 2 years time before the right one had significant play in it. So it was about 4 years, 10,500 miles in the case of my car. When I pulled the arm off to rebuild (at that time having no idea what a "febi" kit was), I found the same thing you did and had to source a used a-arm from a fellow rennlister. I don't know how the car was driven before I bought it, but I don't think it was driven too hard. I did several autox events with stiff springs installed, but the car was/is not a daily driver for me and rarely sees bad weather or rough roads.
Good luck!
How can you tell when a ball joint needs to be replaced? Do you have to take the a-arm off and make a visual inspection, or are the signs you notice while driving?
How do you tell if used arms are rebuildable or not? I was keeping a set off my '88 around to rebuild myself but I may consider selling them. Of course I would want to make sure they are rebuildable prior to any sale.
Stick a prybar or large flathead screwdriver between the end of the a-arm and the knuckle on the spindle that holds the top of the BJ pin, and pry. If there is play and the pin moved in/out of the socket in the arm, it needs rebuilt.
Thanks!
