Need a piston (possibly 2)
Looking for tolerance group 1 piston. I may need 2, but I know one for sure. I'm waiting to get this second engine totally apart, but the first one I pulled was in pretty bad shape.
If you cannot use tolerance 1 pistons in a tolerance 0 cylinder (if it turns out that's what I now have), does anyone have a set of 4 tolerance 0 pistons? Or does it make more sense to remove enough material (nikasil) to make this a tolerance 1 block again?
What does tolerance group mean? Is that like first and second oversize?
There was a guy in Ottawa selling pistons on ebay recently, not sure if they are still there.
yeah, this block was pretty messed up. we had a local guy who was willing to give nikasil a shot if we could find the correct rings, which we did (964 oem). I have not measured the cylinders yet, hopefully he still has the dimensions, but i'm thinking he may not have given me tolerance 1 specs.
If tolerance 1 pistons will work, how much do you want for 1 or 2 of the pistons?
the tolerance grouping is how tight the tolerances are held. tolerance 0 is 99.98 +/- 0, tolerance 1 is 99.99 +/-.005(mahle) +/-.007(kolbenschmidt), and tolerance 2 is 100
cylinder:
tolerance group 0 is 100 +/-0, tolerance 1 is 100.01 +/-.005, tolerance 2 is 100.02
yes, but i believe the problem was sulfur content related. poor quality gas caused problems with these engines fairly quickly. i think gov't regulations limit the amount of sulfur in our gas now (i could be wrong).
might be the quality or grade of the nikasil blend. i'm not sure what percentage of each component is required for "nikasil", or if there even are grades. could have been a process related issue as well, i don't really know enough about it.
