V8 in, early review
#31
Originally Posted by J Chen
Hi JPR,
Great conversion. BTW have you not considered
the LS2 ? Is it dimensionally different to the LS1 ?
Jpr
#33
Originally Posted by turbo8
i would like to go that far with the LS7
but one can always dream
regards
Ed
#34
Originally Posted by Crazy Eddie
I'd like to have a full head of hair and look like I did 10 yrs ago... Oh and wife with big **** that does whatever I tell her
regards
Ed
regards
Ed
ive got that now haha just not married haha
good luck
#35
So what's the difference between the guys you went to and Renegade. They are here and I thought they were a good company. Yours look very clean. I would do it.
#36
You know, I'm wondering what that would do to the value of the car. If I did it, I would have over 700hp, I already have about 600. With that clean of an install, coupled with the shape the rest of my car is in, do you guys think my car would still appraise out as 60k? Hot Rods regularly appraise for that and more. Would that be considered a hot rod?
#37
Jpr
#40
Excellence did an article a couple issues back of a 968 with an LS2. Renegade changed hands at some point in the past and now are trying to address the LS issues as they used to do only the LT. If you buy everything from them it adds up quickly, but most V8 swappers say they wish they hod done it sooner. The Excellence article also addresses the value factor.
I've watched the board and have read good things about German Performance in Florida. Tony G made a strong case for the LS series motors in the 951 on this board a while back and he seems pretty sold. It all depends on what you are looking to achieve.
As someone said, the LS7, which is the ZO6 motor, will fit. That is an aluminum 427 with ...what...500 HP at the flywheel. Swapping ain't cheap though.
#41
This was posted over on the racing forum, nice to see the entire drivetrain can be transplanted.
First ever grafting of the Corvette C5 torque tube, transaxle and rear dual A-Arm suspension into a Porsche 944 turbo chassis.
http://www.cardomain.com/ride/2640341
PorVette Endurance Racing Team
https://rennlist.com/forums/racing-and-drivers-education-forum/390708-2-seats-available-in-overall-race-winner-for-25-hours-of-thunderhill.html
#42
Rennlist Junkie Forever
I've got my 951 with a V8 in it ( www.tonygarcia.org/944V8 ). I used a Bendix hydroboost with a 2004 Mustang GT master cylinder with remote brake fluid resovior.
I drilled the hole in the brake pedal 1/2" higher (closer to the pivot point).
The brakes work as good if not better than they did with the vacuum setup. The feel is perfect. I've used the setup on the track 8 days now. Zero complaints.
I did not use the factory proportioning valve. Rather I plumbed in a Wilwood in-cockpit adjustable proportioning valve (about $100 with hoses). Works great. Really lets you dial in the brakes on the track.
If you need, I can PM you the place that did the job (they are in Long Beach CA.. but I forgot the name). Cost is about $1200 installed (probably about $750 for the parts if you do the install).
TonyG
TonyG
#43
Oh...
And congrats on the V8 install. Don't you wish you did it sooner? :-)
When you're ready, check out the HP Tuner software. You can log in and totally customize your air/fuel ratios and timing. When you see the range of adjustability with the factory computer your jaw will drop.. Amazing how far car computers have come since the 951 DME.
TonyG
TonyG
#44
That's a good purchase, Tony! I've gained 38whp/30wtq with HP Tuners, but my AFR was WAY out of tune post swap. You'll notice a big difference in driveability as well, through adjusting your fuel trims. No matter what someone tells you, mailorder tunes suck!
#45
As an aside, is it possible to use a 'Vette gearbox in our cars? Are all you guys just going through the stock 5 speed 951 box?
