Anyone Interested in an Almost Awesome 951?
#77
Hang in there. You have a sweet example with the Andial motor. Give it some time to work the bugs out and you will be rewarded :-)
Originally Posted by 944TurboStar
Yes I was going to but now I am having trouble with a fuel leak from the injector....i caused somehow when trying to fix bad idle by replacing ful damper. Anyway I am having one guy come and fix the idle and then I will take to Devek for tuning......if things dont work out after that it will be up for sale.
#83
Well the car should be done today. The waxing part that is. Next I just need to get the car on the dyno and have the final tune done. I hope to have some good numbers. I am not looking to get 400 WHP at an insane amount of boost. That is not my goal. Heck I could probably get to this number but then my car wouldn't last to long on the track. I am hoping to get 340-350 WHP and a comparable torque number at a moderate boost level. My Wolf3D has been setup so that I will have a toggle switch to change boost on the fly. This was installed incase I get hung up at the track. Someone may be a little quicker than me in the straights but will hold me up in the corners. With my switch I can change my boost on the straight by a couple of pounds, get past them and then put it back to my normal settings. Just a handy little device. I'll post my results if anyone is interested.
#84
Here are a few pictures of the car. I apologize that the corner of the hood is creeping up. The K&N filter is not allowing the hood to flly close. I will take care of that soon enough. Enjoy!
