arc-2 with arm-1 for sale
yes to my knowledge it was from huntley because i have a huntley racing MAF so i am assuming that the arc2 is huntley also. It is in great shape i don't think there is any scratches since it has been in the glove department. i will take pics if u want them. Also all the lights light up on the arc2 and arm-1. i am selling cause i am going with a safc2
you do not need an ARC2 with the stock AFM. The DME will get crazy except if you disconet the wire from the AFM
You can just remap the chip on the stock car why do you want an ARC?
Konstantin
Konstantin
UAE Rennlist Ambassador
Konstantin
Konstantin
remaping the chips is more accurate than play with three buttons.
You have 144 points to do that on the chip. With the ARC you go up or done in three groups. Actually you can use only one button
the first one is for idle only. (the chip has 5-7 points)
the second one for middle (Part throttle) (144 points)
the third for WOT (16 or 20 points)
Konstantin
Konstantin
The ARC2 (if connected properly) works with the AFM. I don't see the need for it, unless you want to do "minor" adjustments to your AFR.
yes I just sent you an email. I have an older HR maf here.
Konstantin
Konstantin
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
