Help! Stuttering blues
I've had this problem for a while now. The car stutters or misfires between 3500 and 5000 rpm in third or forth gear. It only does this at complete WOT. The boost rises correctly but the car jerks and shudders at around 4000 rpm. Driving around town or at almost WOT doesn't induce this, it's only during extreme acceleration. Sometimes it does't do it at all, other times it's real bad. Can someone list all possible causes for this? I am going to replace chips, wires, cap and rotor to see if it will fix it. I just want to know any causes so I can narrow it down.
Thanks, Josh
Thanks, Josh
Pressure test the system for leaks. Check your spark plugs.
Remove your plug wires & measure the resistance of each
wire by using a DVM also check rotor & cap.
BTW is this a recent problem ? If you're still running an AFM
there could be a problem there. How to check, I don't know.
Perhaps someone can chime in on this. Oh, also check the
boot after AFM/MAF.
boot after AFM/MAF.
Sounds like overboosting to me...my dad's car did that same thing too exactly how you described it. That being said, in your sig it says autothroity chips. My understanding of aftermarket chips is they have no over boost protection.
Yes, I have the Autothority chips in it. Does that rule out overboost protection? I looked at the distributer cap today. Should the contacts be bright and shiny; or is a little charring normal? I hope by getting new wires, cap, etc; I'll solve the high rpm stumble. What else could it possibly be, a fuel system problem?
Thanks,
Josh
Thanks,
Josh
UAE Rennlist Ambassador
Take a loook at the coil, plugs, wires etc (the ignition system). Make sure the cap doesn't have any cracks or parts missing.
second the batt leads. They can deteriorate and can(it happened to me) cause this kind of symptom. Replaced the + lead from the battery as well as the ground. all gone. You appear to have a borla exhaust so it shouldn't be cat blockage.
Rotor? don't know. Cat? It could, but I would think that it's not very old, and those are pretty good systems. It should take some pretty good time to clog a new cat. My stock cat took about 17 years to really clog. Too long. Yep. Probably could have been changed 4yrs? earlier? However, what would happen too me was that I would stomp on the trhottle, all was normal then an almost split second shut off/ stutter(call it what you want) It will scare the crap outta you in the wrong situation. After replacing fuel filter, pump relief valve, cat(deleted all together) timing belt. the positive cable burned in half. It was touching somewhere on the back of the engine area, and just burned up.
i think that the thrust of being at full throttle would get the damaged area to ark with some part of the housing. the jolt moved the cable marginally, thus stopping or creating proximity for an arc. We still aren't sure. we do know that it is all gone. After replacing both battery cables completely, I found that the voltage reg wasn't working and replaced it.; (entirely too much work to change a 15.00 volt reg) As if by magic...err ...electricity, the entire electrical sywstem functions beautifully. Who'd a thunk it huh? I think all of these posts are worth really checking out. Old wires+ brittle, unreliable electric signals. Use Clarks garage, and forum to help w trouble shooting if you can't isolate it. You'll find it. Good luck.
