Calling Huntley Stage III MAF users
I have a chance to buy a Huntley MAF w/ chips used.... What is a good used price for one of these and are they any better than say a Vitesse Maf or Lindsey Maf...or any other Maf for that matter? Also...does anyone have a pic of the Huntley Maf installed? Thx
Vitesse MAF install is a plug and play to stock connectors other than 1 wire.
The Huntley I had used no stock connectors was all wired into an ARC 2 and DME harnes, not a simple job.
Vitesse is local to you and you have seen first hand what John's customer support is like.
Originally Posted by J Chen
Hi David,
When you say not up to Vitesse standards,
do you mean the resolution of the ARC
as compared to the SMT 6 ?
Vitesse chips are very close to spot on without the SMT6, the Huntley chips were not.
I relate it too buying a 5 year old computer verses today standards, works but...
Hi David,
I wouldn't go into details of the advantages of doing the signal recognition on the chip, it has been discussed plenty. Perhaps people that switched the AFM chips to use Vitesse MAF chips with their aftermarket MAF would share their experiences...
We use the SMT6 for fine tuning purposes not to convert the MAF signal to look like an AFM..
I got almost 30 RWHP going from ape to Vitesse with Autothority MAF. This was before I really tuned it well with the SMT6 - which made another HUGE difference.
I have gone through 3 sets of AFM chips and 4 sets of MAF chips, and the Vitesse are the best. And you can really make your car come alive with the SMT6, if you want to.
I still cannot believe the extent that I can easily tune my car and the price.
I believe I could put a stock cam on my car and tune the afr very close in a couple of hours.
If you drive around with the SMT6 on your laptop - even if you have the slightest hiccup, you watch the tracer which tells you in real time the exact load cell you are in and you adjust. SIMPLE. Really, I think even Hosrom could do it.
The Huntley MAF setup is a Ford MAF, it works just fine. The issue isnt with whether one MAF is better than another, the issue is whether one piggy back is better than another. There are certainly better mouse traps than an ARC-2 but it does its job just fine.
Special tool, I have to ask since you are using it as an example, were you using your APE MAF correctly? If so 30HP is not only believeable but I would imagine a little low as you should have picked up more boost.
Caveats, addendums, release forms, etc below
I have not used John's MAF setup, I have used more than one Huntley MAF.
I would NOT buy from Huntley and I WOULD buy from John.
I prefer the SMT-6 to the ARC-2. Both work, however.
Cant think of anything else to endemnify myself from
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Oh crap, how could I forget that. BTW, I am still waiting for the document we were talking about yesterday RE: priming. I got the pics and you have Email. Thanks for helping install the turbo yesterday, I might even get the urge to put the other bolt in tonight!
Wow, very proud of you! I'll send the form over now. Give me a call if your hanging around. My work went just went to hell.. My monday went so good, I'm going to have to take the rest of the week off !
I will be home about 1800 if you want to stop by. That will give me time to feed the dogs. Just give me a call this afternoon, hell with the right amount of work/help I might have it bolted in with the intake on tonight, then I could actually being putting the car together! WHO KNEW! I am probably going to order the V-band clamps on Monday, you want me to order you some as well?
