Zeitronix WB question / thought
#32
The LC-1 has programmable outputs built into it, no $40 add-on boxes needed. You can use a narrow-band AFR gauge with it, no problem. Obviously in addition to its wide-band output to whatever you're logging with or an EMS that will accept the WB input.
http://www.innovatemotorsports.com/products/lc1.php
$200 or less shipped, if you do a little shopping.
#33
If you do not want to go through the hassle of converting to round gauges, my install is the best route. However, I have a hard time with the location. takes a lot of effort to watch all the #'s and stay on the orad. its too far from my line of sight. It looks nice thoug.
~Eyal
~Eyal
#34
Saw a device on a guy's 951 at a car show last October in Austin. It was a little projector thing that went in the defroster vents and projected a heads-up display on the windscreen. It looked pretty cool. The owner said it could be configured to display just about anything.
