Garrett GT series Turbos
Old 08-26-2010, 12:55 PM
  #166
Scott H
Scott H's Avatar
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
Should be what you need, if not, they should carry it.
Old 08-26-2010, 07:27 PM
  #167
blown 944
blown 944's Avatar
The KKK turbos have a double seal on the turbine side and are not as finicky.. The garrets always seem to need a restrictor. Do you still have the AOS plumbed into the inlet or is it vented to atmos.? They seem to need to be plumbed back in on a street car from what I have found.
Old 08-26-2010, 10:18 PM
  #168
TRP951
TRP951's Avatar
Ive been running a GT35R HTA turbo on my 951 for a couple of months and it spools quite quick although I need a new gasket between the crossover and the turbo inlet
Old 08-26-2010, 11:03 PM
  #169
333pg333
333pg333's Avatar
On a 2.5? Mods? Where are you seeing boost?
Old 08-30-2010, 09:23 PM
  #170
TRP951
TRP951's Avatar
Sorry about the delayed response I have been quite busy lately.
I am running a stock 2.5 longblock with mild headwork, SFR stg 1 headers, custom crossover, 3" exhaust (downpipe to muffler), TEC3r, custom IC. I am seeing 1 bar ~3700 but I do have a leak at the turbo inlet which I just have to find the time to replace the gasket. It is also running rich as I cannot tune it for better spoolup until the leak is fixed.
Old 08-30-2010, 10:09 PM
  #171
333pg333
333pg333's Avatar
Under the circumstances that's still very early boost for a big (for us) turbo.
Old 08-30-2010, 11:05 PM
  #172
TheDice951
TheDice951's Avatar
Originally Posted by KuHL 951
If it's a ball bearing turbo you need a restrictor installed at the oil inlet of the turbo. Without a properly sized restrictor you will blow oil everywhere since the OE KKK turbos were journal bearings and required oil pressure, not splash lubrication like a ball bearing. Garrett determines what size orifice you need from the oil pressure of your model of engine.
i dont meen to steel the thread, i just have a question... i have a huntley stage 2 turbo that was installed 10 years ago.... from the PO's records he has had problems with oil leaking from the turbo out the exhaust from like 2 months after the install. he never had it fixed, im wondering, because i was told its a BB turbo, could it be just because no restrictor is installed? the factory oil feed line is installed...?
could this fix the problem even after 10 years?
Old 08-30-2010, 11:31 PM
  #173
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
BB turbo, 10 years ago?
BB turbos do need a restrictor, so you that could be the issue - but I would first confirm that you actually have a BB turbo...
Old 09-02-2010, 08:46 AM
  #174
TheDice951
TheDice951's Avatar
the reciept says "garrett ball bearing turbo" but who knows... no part numbers or anything though and i havnt taken a good look at the turbo.... it was all installed in 2000 by some shop in tx.... i am planning on replacing anyway so its not a huge deal.....
Quick Reply: Garrett GT series Turbos
