Official post-ZT-2 wideband GB installation thread... Q/A...
#46
Originally Posted by schnellfahrer
Hmmm...I think I have two of these
Easiest way is to grab a voltmeter and test it. Switched it would come on with the key is in and turned to one of the clicks (any of them should work). The ground is easy, just find a spot where a ground wire is bolted to the body.
#48
Thanks, Brian. I think I'll solder them.
Since its a tube, you have to cut the wire, slide it on, then solder away. I dont like doing this, so I usually solder everything up, wrap it tight in electrical tape, then use small zip ties so that it keeps the tape on AND holds the wires together so the solder doesnt brake.
#49
#50
got mine this afternoon and installed it, only took about 30 mins. i didn't install the TPS output because i couldn't figure out what i'd ever use it for. what do y'all use it for? also noticed that the AF ratios that the zeitronix were showing were quite a bit richer than what the wideband at the dyno showed (9's versus 11's).
#51
Which brings up the question of what kind of accuracy we can expect from the device. How does it compare to the devices used at dynoshops?
#55
hi tom,
unfortunately i was unable to correlate my readings with the dyno's wideband since we didn't use it. however i did discover why my readings on the zeitronix looked too rich at first, namely that my boost settings had dropped off some. with that fixed the zeitronix readings looked at lot like the dyno wideband readings that i took a month ago.
