Possible oil pressure problem
I recently noticed that when my car idles, the oil pressure indicates pressure lower than '2' on the guage. Also when I first start the car it takes a while for the oil pressure to build. However, upon a gentle tap of throttle leading to an increase in RPM to 2500 and above the oil pressure guage indicates its maximum value. Is this normal for a 1986 Turbo?
Thanks you for your feedback.
UAE Rennlist Ambassador
Which oil grade are you running?
I get 1.5~2 bar oil pressure with a/c and some hard driving. I run on 0W~40 oil (REALLY REALLY thin).
I used to get 2.5~3bar on idle using 15w~50.
Anyway, anything over 1,800~2,200rpm you should be reading 4bar+.
Again, check the grade of oil (oil weight) because it REALLY effects your oil pressure, as well if it is synthetic or normal.
I got worried after oil change when mine went down to 3 bar at hot! It never used to go below 4bar. Checked it out with a wet guage and it is reading correctly! Concern over nothing it seems!
Yeah, I have noticed much lower oil pressures with M1 15w-50 than with Chevron 10w-40 conventional oil. This is especially the case when the ambient temp is high. My 2k+ rpm pressure actually drops a hair below 5 bar with the Mobil 1 15w-50....hmmmm...it didn't happen with the cheapo Chevron oil.
Max
Max
Hey Man
Max
Max
Steve
Originally Posted by hosrom_951
Syntheitcs ALWAYS read lower oil pressures
I think M758 switched to Amsoil racing synthetic and he says he sees much better oil pressures than with M1 or any conventionals.
Max
Surely high oil pressure is not the be all and end all. Whats important is the quantity of oil thats is getting round the engine.
As the oil heats and gets "thinner" less viscous then it takes less pressure to pump the same volume of oil.
Runnig with 0-40 is not bad for the engine in terms of wear, just means that you might loose more thought the seals than a "thicker" oil.
could be sludge in the sending unit lines as well that is dampening your readings
remove the sending unit and spray out the inside with some carb cleaner
