Valve Spring Replacement: Head Rebuild
Spell Checker
How many of you have replaced you valve springs when rebuilding your cylinder head. I spoke with the shop who is working on the head for me, and they are saying the valve springs are showing an 18-20% degredation in rate from factory spec. The cost to replace the springs is ~180 for OEM springs. Between the cylinder head work and the cost of O-ringing the head, this is starting to add up :-(. I am also having to replace two exhaust valves due to cracking. Again the OEM valves are not cheap. What do you guys think?
Try ordering a set of valve springs from Pelican Parts - much cheaper than $180 for the set. I think I paid around $100.00
I've looked in the factory manual for specs on the valve springs (free lenght height, compressed values, etc) and the only value I found was the installed spring height. This height is adjusted with shims placed under the lower spring retainer.
So, if you're being told that your springs have degraded 18-20%, ask which spec they are using to determine this and if/where these values are in the factory manual.
HTH
Vic
HTH
Vic
I have change all of them with OEM. It was include in the "while I'm in there" things. Sure they can be costly, but I'm sure after 16 years they were a bit softer. (every engine rebuilder told me to change them... and the valve seal and the guide...).
Spell Checker
I also only found installed height in the factory manual. I suspect he is comparing the values for each of the springs against a value gotten from a sample of new OEM springs. I am going to ask him in the morning.
Done With Sidepatch
Guess you have to ask yourself how often you plan to remove your head a rebuild it. I don't plan on doing it again for a pile of years so I replaced my valve springs during my rebuild. The set I picked up cost me a $100 as well.
Spell Checker
Pelican was down earlier. I found the $14.00 per valve springs on their site. Are these OEM Porsche springs? Anybody know? Guess I'll have to wait until Business hours tomorrow to find out.
