Sealing oil pressure sender, RTV or Threadlocker?
I recently replaced my oil pressure sender, the old one was leaking and would pin to 5 bar at anything above 1.2krpm or so.
When I put the new one on, I torqued it down but it started "weeping" oil immedatly from the join. I wiped it clean and checked after a while, and it was weeping pretty good. So I cranked it on tighter, still it stopped weeping and figured that was ok. Now it leaks, pretty heavily.
I figure ill take it off next oil change and seal it up, my mechanic suggested doing this if I wanted to. My question is, what would be better? I have blue and red threadlocker, and Ultra Grey RTV which I think is oil safe...
And yes, the crush washer was on there the whole time.
Threadlocker is not designed to be a sealant.
If you're concerned about leaking and don't trust only the crush washer, use some RTV. Most of them are oil and pressure resistant, just get something that is rated up to 300 degrees or so.
Pick yourself up some High Temp Permatex Thread Sealer...item# 59214. I used this on my oil press sensor with great results. It does not dry hard either so you can remove the item as well when needed.
Make sure you use the crush washer, and it is only good for one use. The HT sealer from Permatex is good but I've had good results with plain old white teflon tape.
The washer is on there, it came with the sender, and the washer was on the old one, both leak in the same way ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Anyway, RTV it is and maybe now my lonely oil leak will be gone
<Pounds furiously on wood for a few hours>
Thanks guys.
Thanks guys.
Originally posted by J Chen
Check to make sure that the
housing isn't cracked. Mine
leaked & found out that there
was a crack.
was a crack.
I would use Teflon tape or the goopy Teflon thread sealant as well, RTV is somewhat oil resistant, but Teflon is far and away more oil resistant than any silicone is or probably ever will be. (Dare I say oil proof with Teflon?) For an oil pan gasket RTV is a better choice in that it sets to a shape, but for a threaded seal application the Teflon is a much better choice.
Eventually, almost any silicone will break down with continual oil exposure. Teflon won't. If you are set on an RTV, just make sure you at the very least use something like an ultra gray or ultra black silicone as they're a bit more oil resistant and won't break down nearly as quickly..
