She FAILED guys & gals!!!!
zipped over to emissions testing in order to get my new plates - SHE FAILED - on the NOx test - what should I so now - anybody got any ideas where to start - O2 Sensor??
thanks for the help - gotta get plates!!
tom
tom
i'll have to look at the vacuum lines (they all needed replaced anyway) - as for the cat - i have another '86 cat - will this mount-up to an '88 OR should I splurge and go with a new free flowing cat?
pardon my ignorance - what is AFM?
thanks
tom
thanks
tom
dam u dam u all who don't have emissions!! - i can only dream of running a cat bypass pipe!! anybody have a good suggestion on performance exhaust w/cat?
tom
tom
the test is a rolling - steady hold at 25 mph. the car is pretty much stock: chipped, shimmed WG, K&N intake kit - BUT stock beyond that!! I just replaced the fuel regulator and damper, new plugs, plug wires, coil cap and rotor.
i'm thinking i'll start with the O2 sensor (have never replaced it), in addition, replace all the vacuum lines. A new cat and exhaust surely woundn't hurt - still running the original equipment.
-tom
-tom
Check for vacuum leaks. The lines, the BOV, fuel breather valve, heater control valve, anything connected to the vacuum system. Check for cracks in the J-boot.
will do - the J-boot is brand new - i'm still thinking vacuum lines maybe the simplest check and fix - i'll check those out to night! On a side note - does anybody sell and complete vacuum line kit and coolant hose clamp kit?
thanks
tom
thanks
tom
Monkeys Removed by Request
thanks
tom
thanks
tom
thanks - i thought maybe - AFM = air fuel mixture
