Rear support bar.
Old 07-10-2023, 08:00 PM
blade7
blade7's Avatar
Default Rear support bar.
I see a company is selling a 'rear support truss', that mounts between the C pillars, above the rear seat back. Is a bar mounted there, going to make much difference to the shells rigidity?
Old 07-10-2023, 09:11 PM
931guru
931guru's Avatar
No.
Old 07-11-2023, 12:45 AM
spencang
spencang's Avatar
I made a custom one and connected it to where my rear seat bolts were. I noticed the difference immediately. A friend of mine who was following me on a twisty road kept commenting on how flat my car was too. Name:  photo876.jpg
Old 07-11-2023, 12:46 AM
spencang
spencang's Avatar
I actually made this about 3 years ago...
Old 07-11-2023, 05:15 AM
blade7
blade7's Avatar
That's what I'm thinking about doing, got some suitable parts in my garage. The one being sold mounts to the seat belt fixings, which seems less effective to me.
Old 07-11-2023, 07:40 AM
GPA951s
GPA951s's Avatar
From a practical point of view i dont see how this helps in any way, there is really no “ side load” there.. just the shock mounts.. sure the torsion plates are close but the are for the vertical load..
i think if it made any difference the turbo cup cars would of had something like this. The engineers felt compelled to build in a front strut tie bar right into the chassis, but they overlooked this?
Old 07-11-2023, 08:43 AM
blade7
blade7's Avatar
The Cup cars had a proper roll cage, so didn't need a bolt in bar there. It seems to be a known thing on some other makes though, so as it would cost me next to nothing I'll give it a try. I wouldn't pay $250 for one, or fit it between the seat belt mounts though.
Old 07-11-2023, 09:02 AM
968to986
968to986's Avatar
I have a Weltmeister harness bar on my car, but I’m not sure I noticed any difference in rigidity. People think it looks cool though, so there’s that.
Old 07-11-2023, 11:23 AM
V2Rocket
Rainman
V2Rocket's Avatar
In 2006 or so I essentially made one of these on my car.
I got some ~5/8" OD rubber hose and cut 3/4" long pieces and put those on the "pegs" that the rear seatback would latch do. Then I spanned the two posts with a piece of steel pipe ~7/8" OD and 5/8" ID (have to take the seat pegs out of the car, install the pipe between them, re-bolt the pegs to the car and then adjust the pipe a little). The pipe compresses the rubber hose "bushings" and fits snug.
My purpose was just to keep objects in the trunk from sliding forwards since I had removed the rear seat.
Old 07-11-2023, 11:50 AM
blade7
blade7's Avatar
How is that mounted to the shell?
Old 07-13-2023, 09:47 AM
blade7
blade7's Avatar
What do the seat 'pegs' bolt into in the shell? I just loosened one, and it seems to bolt into some kind of adjustable captive nut, behind the panel. I was concerned that this nut might drop down if I removed the peg.
Old 07-13-2023, 12:25 PM
V2Rocket
Rainman
V2Rocket's Avatar
It is a captive nut plate but it won't fall down when loosened,
blade7 (07-13-2023)
Old 07-13-2023, 12:31 PM
blade7
blade7's Avatar
Thanks. I found a pic of a stripped out shell, and that explained it.
Old 07-15-2023, 05:02 AM
Droops83
Droops83's Avatar
If you want to go a step further, a bolt-in roll cage is a thing. I installed an Autopower 1/2 cage in my '86 951 about a dozen years ago, and the most noticeable effect was any hint of hatch squeaking was immediately eliminated due to the localized increase in torsional rigidity. There are articles here and elsewhere about adjusting the hatch pins---the Only944.com hatch pin inserts are a great product.
Old 07-15-2023, 12:21 PM
blade7
blade7's Avatar
Don't want to go to a cage on a road car.
Quick Reply: Rear support bar.
