944 Turbo (wet) weight
#47
With 1/2 tank gas, no spare, jack, rear seat, tools, my 3 liter was 3050 lbs. It's got an airbag but no abs. I think Porsche claimed 2998 lbs for it in the owner's manual, with the original 2.5 liter engine.
#48
curb weight has something to do w/the weight minus certain options, etc- ACTUAL weight, OR, TEST weight is a better #- it's more of what you would have the car weigh when you are actually driving it, minus driver/passenger/personal items, weight- some people mistakenly assume that the driver weight is part of actual/test weight, but, it is NOT. the tet weight is normally used w/half a tank of gas- all fluids, etc, are all full, as hte car is in driving condition & all options, etc, for hte specific car are included- actual weight is normally ~150lbs heavier than curb weight.....
corner balancing- you weigh the car at each corner while aligning it & raise & lower given corners (by raising coil over height OR lowering) to get the same amount of weight at each corner or to get it balanced diagonally- you would want the weight of the left rear + right front to equal the weight of the right rear + the left front IIRC- racers do this to optimize handling- by raising the right front corner of the car a tiny bit, you will add weight to the left rear corner of the car, etc- this is usually done w/the driver in the driver seat AND a half tank of gas....
#49
Monkeys Removed by Request
Yeah like I said I weighed in at 3047lbs with half a tank of gas/spare/stereo/ect. I have abs/airbags/lsd/headlight washer's/turbo seat's/ect. So I think my car would be about the heaviest of the group. Even still I thought 3047 wasen't all that bad. I could easily take out a couple of hundred pounds.
#50
3047 isn't that bad, but, I doubt you could remove more than another 100 w/out ruining the car pretty much.... for TRACK it would be different though....
I HATE thinking about weight w/these damn cars- makes me think of the CS's, etc- they really sucked- they removed most of their weight by removing sound deadening- something they needed more of to begin with, not less- then, they did NOT remove any of the wiring harness- lot's of parts are so light, that the wiring to run them is heavier than the deleted part itself- like the power to manual mirrors- not to mention the dumbass way they did the rear seats- they got rid of it & gave a storge bin- BUT, they STUPIDLY used a THICK-*** piece of wood that actually ADDS weight, even when you consider the deleted rear seatbelts, etc.... anyway, I digress- doesn't matter b/c I'll never but one anyway..... I'll be lucky to outlive the POS I have... Can't emphasize ENOUGH how frustrated I am w/this car right now..... oh welll rant over....
#51
[QUOTE=Robby;1396283]I would love to find out.... Chris Cervelli always called the 944's Flexi flyers.... can't imagine the Integra having much lighter chassis- 450lbs isn't much for the whole body.... the integra couldn't have been as good a chassis, but, I have to wonder- it DID handle fine- my turbo S doesn't handle for ****... VERY FRUSTRATING.... Not sure what to do anymore.... 275lbs springs (too much) 100lb helpers (perfect) w/LEdas (I HATE them) & Stock Turbo S sways w/968 caster blocks & 17's w/Pilot Sport PS2's- the tires have a TON of sidewall flex & I can't Find ANYONE to tell me WHY..... any input?
Just wondering, did you try looking at aftermarket coilovers for the 944? If anything top quality aftermarket coilovers can do wonders.
#52
How much do the U.S. spec bumpers & mounting structures weigh?
It seems that late European model ('88-'91) generally have a curb weight around 1400 kg (3086 lb) with full fluids & half a tank of gas.
Earlier models (''85 - '87) are perhaps 50 kg (110 lb) lighter on average.
#53
[QUOTE=Ilove904s;18335960]
That's the best thread resurection I've ever seen. Over 18 years!
