Motor mount bolts
SeaCay (02-12-2022)
Got the bolts. I have the driver's side mount removed but having a fit trying to install new OEM mount. I've followed the Pelican DIY, crossmember bolts max loose both sides but still in, floor jack w/wood under oil pan raised engine as far as it will move, anymore and car starts to lift off jack stands, w/prybar crossmember as low as it goes. Note: driver's side mount 17mm bottom nut/washer removed 13mm top still in, Is this correct? Do I need to remove steering rack mounts? Please confirm orientation of new mount as you twist it in and it does have to go in from the front correct?
I do love me some Bellmetric but if I need a larger quantity and the next day I use McMaster-Carr. However if you like the yellow zinc BM is Bomb!!
McMasterRaceCarParts to the rescue
Mike G.
Mike G.
New motor mounts install complete. Steering wheel is now slightly off center. I assume due to loosening crossmember and not returning to same exact position? No big deal? I am scheduled for new alignment anyway due to lowering front ride height.
If you removed the rear control arm bushings/caster blocks (which is usually required with front cross-member removal), then the caster and this camber and toe will be slightly off. It sounds like you were already due for alignment, so get it done and all should be OK.
