What Metal are M030 Spindles?
The "flat" in the threaded section of the spindle is to locate tab of the washer that goes behind the spindle nut.
Thefu
Not having any made. Just working on my suspension. Have to get them drilled to accept 19mm ballpoint pins, would be nice to let machinist know.
Not the threaded portion, the steering arm, just before it's attachment to the tie rod.
Flats. My guess.. Counter hold the spindle when tightening or loosening the nut. Otherwise your up against your rack / steering lock
but most people just use an impact
SeaCay (02-26-2021)
Thefu
Makes sense.
No guess on material? One reason I ask is that they don't corrode (at least in my workshop observations). I know they aren't stainless, but there's some kinda metallurgy magicianship going on here.
https://www.sciencedirect.com/topics...tainless-steel
SeaCay (02-26-2021)
I always assumed they are a type of cast iron. They can corrode. I highly doubt they are stainless; that would be extremely costly and not sure of the benefit.
Never understood the overboring on the spindle. You're taking out 1mm of material from an area that gets huge loads. The spindle is now weaker and will be more likely to break.
If you're searching for strength, the whole system is no good by modern standards.
I understand the 19mm and therefore the re-boring. But without extensive testing, there's no way of knowing if it's beneficial. You're strengthening one part but directly weakening another.
Respectfully, saying they've been tested doesn't mean much without specifying what kind. Have they undergone destructive testing with multiple samples? Have they been pushed on a jig to the limit? Then the whole system tested by a professional?
I've heard of an overbored one cracking. I would specify how but don't know.
My car builder insisted I buy new M030 spindles before boring them to accept the 19mm pins - which I've coupled with RE billet hubs and billet aluminium aa-arms.
He felt that with the loads from rose-jointed suspension & R tyres the existing 134,000 mile spindles would be a risk.
