SFR stage 3 turbo... Tim? Others?
Old 02-29-2004 | 03:06 PM
NZ951's Avatar
NZ951
Default SFR stage 3 turbo... Tim? Others?
Hello,
I am about to install (when it arrives!) a SFR stage 3 turbo. It is water and oil cooled. I have decided to run it with just oil cooling and block off the water cooling section. I just want to get rid of the pump and hoses etc. I can also use the wrie to input into my link to adjust the fan temp. So... do you think there will be any adverse effects if I let it run for a couple of mins after hard runs or otherwise? Can I just buy a 944 N/A expansion tank and fit that so its cleaner, without the hoses outlets etc? What else should I know?
Andrew
Old 02-29-2004 | 04:58 PM
B951S's Avatar
B951S
Andrew, Why do away with water cooling??? If its there, use it. I like the security of hearing my water pump cycles 10-15mines after a hard run using a low temp sensor. Peace of mind. You really have nothing to gain by not running water cooling. Link fan on temp is not really gonna do the same as the turbo cooling systems no matter how you hook it up.
Old 02-29-2004 | 05:06 PM
Luke's Avatar
Luke
I think not using water is a housing that is devoped to be water cooled might be a mistake. DON"T forget to use a oil pressure restrictor
Did the injectors make it yet?
Old 02-29-2004 | 05:41 PM
NZ951's Avatar
NZ951
No injectors here yet... Getting rid of the water pump and hoses appeals to me. Lees stuff to go wrong and cleans it up a bit. I dont think there is a difference in the construction with respect to the oil section between oil and oil and water turbos. Correct me if I am wrong someone and I will change my plans. Would I have to run an oil pressuer restrictor if I went for oil only cooling? Else I wont need one?
Old 02-29-2004 | 06:29 PM
Sam Lin's Avatar
Sam Lin
Brings up a good point - likely should use an oil restrictor. If you use a turbo timer for 5-10 minutes after hard runs you shouldn't have a problem. Just don't hook up the water cooling section - do not plug it, air needs to be able to get in and out for thermal expansion. You can just fit the NA tank or plug the Turbo tank securely.
Sam
Old 02-29-2004 | 06:33 PM
NZ951's Avatar
NZ951
Right, Stepthen/Tim. does the SFR stage 3 turbo come with an oil restrictor?
Old 02-29-2004 | 06:35 PM
NZ951's Avatar
NZ951
Where does it actually go? What determines the oil flow I need?
Old 02-29-2004 | 06:51 PM
NZ951's Avatar
NZ951
Actually, If I am running a catch can that does not plumb back in, which I pan to, will I need a restrictor still?
Old 02-29-2004 | 07:11 PM
turbo951fan's Avatar
turbo951fan
I had the SFR stage 2 and ran it without an oil restrictor. I did not have any issues. I am running a KKK 27/6 with just oil cooling but it was designed for that. It spools up quicker then the ones which are also water cooled. I wouldn't use a turbo which was designed for water cooling without it though.
Old 02-29-2004 | 07:14 PM
NZ951's Avatar
NZ951
People keep saying the turbo was designed for it. Yes it has provision for water cooling. How does it differ in the oil cooling function from that of an oil only cooled turbo? That is the important question I feel.
Old 02-29-2004 | 07:31 PM
David Floyd's Avatar
David Floyd
The catch can is for a different issue.
Ask Tim what he suggests on the restrictor.
Old 02-29-2004 | 07:32 PM
NZ951's Avatar
NZ951
Hopefully he will see this post... or Stephen Magown whom I bought it off...
Old 02-29-2004 | 07:33 PM
NZ951's Avatar
NZ951
Where does the restrictor actually sit?
Old 02-29-2004 | 07:50 PM
Sam Lin's Avatar
Sam Lin
Do a search in here, there have been a couple excellent pics posted.
Sam
Old 02-29-2004 | 07:53 PM
NZ951's Avatar
NZ951
yeah I did a search and only came up with a heated conversation between John and TonyG really. I will broaden it perhaps.
Quick Reply: SFR stage 3 turbo... Tim? Others?
