Wideband options
Wideband options
Hi everyone,
I’m going to be ordering a wideband for my 951 and I just wanted to check in for opinions and advice from those who know. I can’t spend a a lot, so I’m looking at the Innovate MTXL plus and the AEM UEGO 30-4110NS. These are both offered by Lindsey Racing though I’m not sure that’s where I’ll order from. They both seem to offer what I’m looking for, which is just a simple and clear readout of my AF levels. The Innovate is a little cheaper but I’ve seen quite a few questionable reviews. Any thoughts? happy Holidays!
I've been using the innovate products for a long time with my stand alone setups. They are a fine product. I've also got a PLX unit, that has worked pretty well for years. As I am using megasquirt stuff, I usually shop through DIYautotune.com. I'm sure Lindsey would be fine as well, as they are a stand up shop.
Running AEM wideband for 6-7 months with no issues. Easy install after having the bung welded in place. Plenty of wire length. Wish the screen was a bit smaller to match my boost gauge but I can live with it. Ran the wires through the cruise control grommet.
Located in the a-pillar it may become obnoxious.
https://www.summitracing.com/parts/a.../?tab=Overview
regardless of the brand make sure the gauge has a dedicated, clean power source and ground.
i chased weird readings with an AEM setup years ago, even sent the gauge back to be checked out.
gave it its own circuit, and it worked fine.
