Power Steering - DIY rebuild or buy rebuilt rack
I have a manual rack on my car and I think I'm going back to power steering (guess I'm just getting old and lazy)
I have an oil leak near my turbo that my local shop will be fixing, so I figured that would be the time to make the swap since you have all the room with turbo removed...however if it can be done without removing turbo, its not as big of a deal. I could just do it whenever.
So questions:
1. Can you get to the upper universal joint without removing turbo? exhaust? Looks like its possible with brake booster heat shield removed?
2. Have you guys had good luck with the rack rebuild kits? My local indy shop said they had mixed luck with the kit (not sure which one he used)...needs some bushings that are not supplied??? I was just going to have him rebuild my power rack, but he was suggesting I just buy a rebuilt rack since with labor it would be cheaper or about the same. Rebuild video looks pretty straight forward, but if the answer to question 1 is no, I don't want to do this job twice.
Any other suggestions are appreciated
So questions:
One thing to consider is that not all ps racks can be rebuilt, any scoring on the main shaft will quickly tear up new seals. I suspect that is why some fail quickly when using the rebuild kits on the market.
So questions:
So questions:
2. I've only tried a "rebuilt" steering rack (which afaik is just resealed) and it leaked badly just outside the warranty period. If you're going that route, you might want to see if Autozone have them. They have them on and off, and they used to come with a lifetime warranty. Personally though, if I have more leaks I'm going to replace the seals on the one I have. They do wear mechanically and if you have a nice solid one I wouldn't recommend taking the risk of exchanging it for something that could be in much worse shape.
I just replaced mine a few months ago. Got a rebuilt at O'Reilly's for $179. That is only twice what the seal kit costs and it is ready to use right away and has a warranty too. If the rebuild kit is not successful you are on your own and still have to buy a rebuilt. It was a no-brainer to me.
It also came with new inner tie rod ends and tie rods (but no outer tie rod ends). Mine were shot and I was going to have to replace them anyway, so another plus to the rebuilt.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
https://www.oreillyauto.com/shop/b/s...4/8d7b332a633f
I looked autozone and they showed one for $187 https://www.autozone.com/suspension-...eVehicle=false
A power steering rack rebuild is not a fun job. Lots of small parts held in very tightly ==> high risk of impossible-to-replace part flying across the garage when you finally get the thing apart (ask me how I konw). Also, the sealing rings are a fragile plastic of some kind, and are very difficult to keep from breaking when reassembling the unit. FInally, the thing is very awkardly shaped, making it hard to clamp in a vice while loosening and tightening bolts and collars. Maybe you'll have better luck than I did, but five years and many projects later, this one ranks near the top of the most challenging ones I wish I had never attempted.
Location: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
I installed a rebuilt unit.
Two weeks later I removed the leaking "rebuilt" rack, rebuilt my original leaking one properly and swapped it out. What fun!
Six years and a million track miles later - no leaks.
Your mileage may.....
1. You can remove the shaft, not fun but doable. I have done it.
2. I rebuilt my rack and it is tough, but mine works great. I had two rebuilt units that started to leak one in a spectacular way. I figured I can always re-rebuild it if it leaks. The autozone racks are not great.
I have a friend who went through the rebuild route, and it didn't work out well. Cheap rebuilds from Autozone have guarantees but are not reliable, as two of them failed for our friend. Save yourself a lot of aggravation and get a quality rebuilt one from 944online. We got one and it's been perfect. He has "a guy" who checks them before he ships them out.
