How much for a clutch job?
Old 01-24-2004 | 12:15 AM
Cyrus951's Avatar
Cyrus951
Default How much for a clutch job?
Car's driving weird, RPMs hopping around, time for a clutch.
How much do mechanics charge, so I don't have to go through the hassle..
Also, how long would it take for a novice of 951s to change a clutch himself?
I hear it takes the pros a good 20something hours..
Old 01-24-2004 | 12:26 AM
Gary Gaukler's Avatar
Gary Gaukler
As a ballpark number, around $3000 (parts+labor) I think.
Gary.
Old 01-24-2004 | 12:40 AM
David Floyd's Avatar
David Floyd
$700 or so and a couple of weekends of your time.
It's not that hard just take a lot of time.
Old 01-24-2004 | 01:19 AM
Cyrus951's Avatar
Cyrus951
What must I remove on the '51 to gain access to the clutch.
$700 in parts, correct?
Old 01-24-2004 | 03:30 AM
Chris Moon's Avatar
Chris Moon
For some great step-by-step procedures, try these:
http://www.clarks-garage.com/shop-manual/clutch-01.htm
http://www.tech-session.com/kb/index...x_v2&id=79&c=4
CM
Old 01-24-2004 | 04:00 AM
Kelly Chiu's Avatar
Kelly Chiu
Strictly German in Pasadena quoted me at 1200 for parts and labor, 2 days lag time. Would take only a day if you push them, but they like to get things right. Mine's going out too, but don't want to do it quite yet.
Old 01-24-2004 | 04:26 AM
Gary Gaukler
Kelly,
$1200 parts and labor, is that for real?? If you consider $700 parts, that leaves $500 for labor... at 20 hours, that makes their shop rate come out to be $25? Where I live, shop rates are $100... :-(
Do you have their contact information handy by any chance? I may have to have a clutch job done in the near future as well!
Thank you!
Gary.
Old 01-24-2004 | 11:32 AM
Kelly Chiu's Avatar
Kelly Chiu
The quote was over the phone, and they use sachs parts.
626.440.1242
I don't think its a 20 hour job, the shop owner quoted me as 2 days of careful work, so 12 hours if pushed. Also this price probably assumes that you have the updated headers and cross-over pipe.
Old 01-24-2004 | 12:48 PM
Cyrus951's Avatar
Cyrus951
Is that quote applicable to the 89 turbos?
The 89 turbo has the 2 piece crossover pipe, whereas the 86 has the one.
Is this correct? I'm reading off of Clark's website.
Old 01-24-2004 | 01:58 PM
K27's Avatar
K27
it's not 20 hrs for an experienced shop, not on the two piece pipe.
more like 10.
your welcome to use my procedure.
http://www.user.dccnet.com/lance.mason/951%20Clutch.htm
Old 01-24-2004 | 02:19 PM
Mike1982's Avatar
Mike1982
I really hope I have the 2 piece pipe to save on the time. I have a '86 951 but it seems to be a later model because when I went to put new chips in, it has the 28 pin and not the 24. So I really won't know until I get under there and look but it's to cold here to do that, 15F right now.
Old 01-24-2004 | 02:34 PM
Cyrus951's Avatar
Cyrus951
You have the Turbo S DME in your 86? Doesn't your car run a little funny?
Old 01-24-2004 | 03:06 PM
Mike1982's Avatar
Mike1982
What do you mean run funny? It was like that when I bought the car always drove fine. Then when I got Guru chips that is when I noticed the 28 pin and had to get a new set of chips for the car. But what would it matter in the 28 compared to 24?
Old 01-24-2004 | 04:58 PM
Danno's Avatar
Danno
No difference the fuel/ignition maps between the 24-pin DME vs. 28-pin non-S DME chips. People who had problem were TurboS owners who found out they had 24-pin DMEs with non-S chips. I made a special 24-pin TurboS DME chip for those folks.
"What must I remove on the '51 to gain access to the clutch. $700 in parts, correct?"
The rate-book says 16-hours to do the clutch and most shops can do it in about 12-hours (2-days). I've found it's faster to just pull the engine rather than work my way from the back with removing the tranny, exhaust and torque-tube.
Old 01-24-2004 | 09:27 PM
Silverbullet951's Avatar
Silverbullet951
Originally posted by Gary Gaukler
Kelly,
Thank you!
Gary.
That sounds about right for me, my Mech charged me 300 for replacing the pads, rear wheel bearings, water pump for turbo, lowering, and fixed a leak in the engine.
I think he would charge me about 500 for the clutch job. So yea, that's sounds right.
Quick Reply: How much for a clutch job?
