Oil pan cracks
Looks like there are scuff marks. The oil pan definitely took a hit, either on the road or someone tried to jack up the car a bit too aggressively when they change engine mounts. I would definitely replace them.
If they don't go through, they're simply casting flaws and won't be a problem since the area is not stressed. The pan will be fine to run. If you're nervous, seal the flaws with Loctite 290.
Lots of ways to test to see if they are actually cracks.
Bright light on inside in dark room
Dye Penetrant
Fill it with clean water and see if it leaks
FYI I just went downstairs and looked at both my spare oil pans and they have casting marks that look exactly like what you have on your pan.
Dye Penetrant
