Porsche 944 Turbo restomod
#34
#35
Beautiful pictures and good luck on the project! Would you mind taking a picture of the front corner of the rear hatch floor, right near the fuel fill "funnel"? I want to see if there is enough room there in that corner for a weld-in plate for a roll bar. Thanks!
#36
Do you mean something like this.
#37
Perfect! So there is enough room to weld plates to the front corners of the hatch floor. Are those spots reinforced by the factory, supported by the frame rails and/or close to the rear suspension pickup points?
#38
Progress:
New rear hatch seal (quite a bit too long)
Bumper
Ambient shot
More holes than two for the license plate is a waste!
Transmission oil cooler
I will be adding a screen-grid guard.
Fuel tank.
And the fuel tank removed because the brand new wiring loom has to go in first.
Bumper
Ambient shot
Fuel tank.
#42
This probably is the only point at which you would be replacing the main harness. So I bought the harness from Porsche.
