Waking up a 17 year dormant 1984 928S
#31
If you are not tracking this car, you might want to just stick with stock brakes. I have never had a fade or any inclination that brakes were anything less than capable and I am a pretty aggressive driver.
Your car, your money. Just buy some good brakes pads and turn it loose.
Thanks for saving me from me John!
#32
Tom, those adapters are for early OBs 928's conversion to S4, not the mid-years (S models), with which you will need a different steering spindle/knuckle and suspension bits for later S4 brakes.
Right?
Right?
#33
Thanks!
#34
I think the person who makes the guardian pump (Ed?) also makes an adapter for a conversion of S-cars ito S4 brakes.
Here: http://perfexmfg.com/brakes.php
Good luck-Hoi
Good luck-Hoi
#35
Thanks Hoi, good option to be aware of.
Progress so far today - I just spent a small beach cottage's worth of money on service items. New coolant hoses everywhere, brakes, power steering lines, uprated rear coupler, thermostat, bunch of new seals, ignition wires and cap and rotor and wire set and coil...
I'll file this under the heading "every Porsche is at least a $20,000 car....".
#36
New Bosch rotor - cap etc all on order. Interesting that the molding thickness on the new one is bit different than the one that was removed. New Bosch one looks more stout.
#37
Did some poking around and the blue soft line leaking from the brake master reservoir appears to go to the clutch slave.
Part #29 below;
I tried searching but didn't come across a how to. Also hoping to get some coaching on what lines can be used for that or if they have to be OEM line. Would a good parts house have suitable tubing on hand/ Could someone point me in the right direction here please?
Thanks!
Part #29 below;
Thanks!
#38
Thanks!
Thread on replacing the clutch master (which includes the blue hose):
https://rennlist.com/forums/928-foru...he-fender.html
I would suggest getting a proper replacement, not just some generic "suitable tubing."
Since you are in SoCal, 928 International is a good place to start. They know their stuff.
Another good source is Roger at 928s R Us. He's in Texas, so it might take a bit longer to get parts.
Both are site sponsors, active participants and well respected vendors in the 928 community.
#39
Thanks Joe, appreciate the response. I actually talked to Tom briefly yesterday and will be running over there on Monday, and will add proper blue hydraulic line to my list.
Do I need to drop the clutch master cylinder for sure did swap this line out? If I do need to do that when this be time to simply replace the clutch master as well because it sat for a while?
#42
Installed the new distributor cap, she fired up faster and was more crisp for the three seconds she runs.
Cleaned the passenger side top forward grounding point on the valve cover.
#44
Just for grins, and feeling lucky on Fathers Day after the best hug ever from my 10yr old I made a jumper for the fuel injection relay. No dice, but still feel pretty lucky.
Off to Harbor Freight for a Noid Light Injector Testing kit. New too to me, cool!
Happy Father's Day guys.
