Installing a clutch master in 10 minutes WITHOUT cutting a hole in the fender
Administrator - "Tyson"
I've seen references to "the string method" but never any photos. So here yea go...
It took longer to fish the string through and tie the knots.
My #1 mistake was forgetting to run a bolt through the holes in the master first to clear the paint out....that made starting the bolts a bit tricky due to the paint in the threads.
STOP CUTTING HOLES IN YOUR 928 TO MAKE THIS JOB "EASIER"
- Attach blue hose first - I like to clamp it but make sure the hose can easily rotate 360 degrees around
- Attach the hard line into the MC, leave the nut a turn or two loose
- Use one long piece of string, fish one end through each hole for the bolts
- Fish a bunch through, you should see it under the car, pull it down to about ground level
- Take the portion of the string from the interior and run it out through the door, at the bottom so you can easily grab this end while under the car
- Fish the string through the holes in the clutch master - be sure to get them orientated correctly or you will install it upside down
- Tie each end of the string to a washer (versus tying the string directly to the master)
- Grab the string hanging out the door and start to pull with one hand, while helping locate it with the other hand
- Once the master is roughly in the correct location, pull the "door string" tight and close the door. This will hold everything in place as you climb under the dash
- From here it's just wiggling things around until you get at least one hole lined up.
- Once the first hole is lined up, cut the string but keep them tight in your hand. Take the end that is not lined up yet and wrap it around the clutch pedal.
- One hand grab the snout of the master, now let the other piece of string to fall through the hole and out of the way - install first bolt
- With the first bolt loosely installed, use a small screwdriver to align the second one
- Have a beer
dcolpitts (10-21-2022)
It would take longer for anyone to drive out here than it took for me to install it solo.
I'm just baffled people are cutting up cars to do this job.
Former Sponsor
- Have a beer
If the last step was moved to the first step...do you feel this would change the end results in any way?
Also, you say attach the blue hose first...but I see a black hose attached and clamped?
Besides these two issues, granted I have others, but they do not apply here, nice write up!
Brian.
Same here, live in the boonies, takes longer to find and wait for some one...than it takes to do it myself, with a little improvisation.
Plus, there is a certain amount of pride that comes along with being self sufficient.
Brian.
Brian.
Brian.
Brian.
Brian.
Brian.
Brian.
thanks for this Erik.
With the new master in place can the hard line to the slave be easily attached?
Captain Obvious
Super User
Super User
The hole cutting is to replace the blue hose not the master, or am I wrong?
Shameful Thread Killer
If done right, the hole cut for the blue hose can't be seen without dis-assembly of the inner fender liner, or high intensity lights, a mirror and a lot of contortion. I cut the hole and it doesn't bother me a bit. There's no structural affect, there's no cosmetic affect, there's no affect whatsoever except that there's a saw line in the inner body where there used to be a stamped steel lining. It's sealed against elements, lets in or out no more or less water/air/heat/cool, and if I have to do another blue hose, avoidance of removing and installing the clutch slave with it's endless bleeding process is time well spent doing other things.
In 20 years when the hose MIGHT need replacing, will you still be doing the wrenching? or even still have the car? I always try to figure out cost benefit analysis before doing such repairs. I replaced mine with transmission cooler hose. I don't think it will ever need replacing.
