Is anyone using synthetic ATF? Pros? Cons?
It's about using synthetic ATF in the power steering system. It's raining and I can either go to the shop or to the barn, and don't feel like doing either, so I cooked up this question...
Martin,
Just before Hershey I rebuilt my PS pump, installed a new-to-me rebuilt rack, and put in a new PS reservoir. I also let the system drip dry for about a week and then added synthetic ATF. Damn if I can tell the difference
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I thought ATF is mostly synthetic nowadays???
Anyways, Dexron VI is flowing through my transmission and power steering. Works perfectly fine in both applications.
Has synthetic ATF any known advantages? I would hope cars burning up because they leaked ATF is not the "advantage". Whether or not synthetic ATF is less likely [or more likely?] to burn if leaked is an interesting query.
No substitute for revamping your hoses if they have not been done already.
The only real difference is it has a more uniform molecule size. So if there is a leak, it will leak much worse.
Other than that it has vastly better anti wear properties due to its increased uniformity.
