New To Me Rough Idle When Cold.
04-19-2017, 07:12 PM
By hand at the quad the throttle switch clicks as soon as I move it forward, and then clicks back as soon as I release to re-seat in the idle position.
04-19-2017, 08:18 PM
What do you know, started her up from cold and is behaving normally.
04-19-2017, 08:36 PM
Idling like silk since 1915 hrs.
04-19-2017, 09:05 PM
Team Owner
maybe you have a throttle cable too tight and messing with the quadrant seated the tight one
04-19-2017, 10:07 PM
Quote:
Originally Posted by
Mrmerlin
Always had throttle switch click on/off at the first pull of the quadrant.
Maybe.
Thanks again Stan for taking your time.
Kindly,
Craig
04-26-2017, 11:14 PM
Just to close the loop, I did change all the spark plugs as well and it now idles well.
04-27-2017, 07:04 AM
MainePorsche
Now there's a clue -
04-27-2017, 08:35 AM
FredR
I do try...
05-01-2017, 11:25 AM
Just to be complete:
Temp II Sensor
Room temp approx 50 deg - 2.9k ohms at each pin
Operating temp - 290 ohms at each pin
