6.5 Litre Xmas come early
#31
Some progress
The downhill has begun, we're putting things back together!
Underneath and engine bay have been sprayed with Garnet red metallic 2 pack and clear hardener.
New 250 amp [claimed 125A @ 900 rpm, 250A @1800 rpm] alternator with overrun clutch has been fitted. The crank pulley has had the 2 V belt sections removed a hey are no longer needed. The Bosch/Mercedes alternator has been moved up, back and in and has a Gates automatic tensioner.
Now to do similar with the compressor.
#32
#34
#36
Electron Wrangler
I rather like the alternator belt tensioning idea. So do you have a regular overrun pulley or a Litens OAD (overrun de-coupler) pulley?
Now I'm thinking about how that could be done with a power steering pump in place - certainly more difficult...
Alan
Alan
#37
#39
EPAS mount
Very good question. As near as possible to the alloy casting section of the steering column.
As I'm completely rewiring it, I'll fit the EPAS unit before the loom is built.
The stock loom takes up a lot of space.
It must clear the brake pedal and the HVAC but I'm sure it's doable.
It costs about AU$4.5k so I need to be sure before I buy the system.
The control unit will probably go on the console where the cruise unit was. [DBW cruise now].
#40
PS pump
If you still want to play with oil Alan, you could do as Mark Anderson [and probably others] and fit an electric oil pump under the guard somewhere.
ZF and others make them.
#43
I really like this alternator and tensioner set you are using! Late model GM's (Holden?) with the LS3 use a similar system on the A/C on the opposite side, as you have here. I suspect you have considered something like that over there, will you use the Porsche style V belt for the A/C or move to a ribbed belt like the alternator?
Can you (will you) post the part number for the alternator?
#44
Alternator part #
