86 LH amphenol terminal connector sourcing
Need a source on terminal connectors and a crimping tool for the amphenol harness. Several connectors are shot and getting intermittent problems.
Thanks in advance.
Thanks in advance.
Inventor
Thanks Porken
My brother just picked up an 84 I told him about your chips can you provide a link he is interested.
Can I ask what tool(S) should I get to remove and crimp the terminals?
I sourced the pins thanks to Porken, but after looking at the tool costs to remove and replace I want to go in another direction.
I am wondering if anyone has a LH 25-pin amp connector for my 85-86. Not ideal but do not want to replace the harness at this point in time.
I know there are other manufacturers that use this if anyone knows of a cross reference or has one hanging around I certainly will appreciate it.
I posted this twice and it did not appear?
Rainman
If you are patient and those are typical Junior Timer pins, you can undo them with a simple push-pin (the kind with the colored plastic grip on the back, not a thumbtack).
You push the wire further "in" from the back and use the push-pin to push down the "finger" that locks the JT pin inside the plastic connector, then pull the wire "out" of the connector. As you see the pin holes are T-shaped - the "finger" is in the bottom of the T.
Takes a few tries but it works...and cheaper than the $50 or whatever pin tool.
As far as putting new pins on bared wires a good "Molex type" crimper should work.
Go to post #47 you'll see the idea I'm copying from Ken Rudd...
Thanks!
Matt.
Inventor
http://forums.pelicanparts.com/porsc...onnectors.html
Good info, I think.
For posterity.
DIY - Harness Connectors
INJECTOR/ECT/KNOCK-SENSOR CONNECTORS, 2-position
Mouser - TE/AMP 85202-1 - female housing, Junior Power Timer, new style finger-operated spring-clip, black
Mouser - TE/AMP 282680-1 - female housing, Junior Power Timer, new style finger-operated spring-clip, grey
Napa - CRB 218457 - new style finger-operated spring-clip, pre-assembled with pigtail
Napa - CRB 218545 - old style square spring-clip, pre-assembled with pigtail
SPEED&REF-SENSOR/SPEEDO/ISV CONNECTORS, 3-position
Mouser - TE/AMP 1-962581-1 - male plug, Junior Power Timer
Mouser - TE/AMP 368356-1 - female housing, Junior Power Timer, new style finger-operated spring-clip
Napa - Echlin ECH-EC173 - new style finger-operated spring-clip, pre-assembled with pigtail
AFM CONNECTOR, 5-position
Mouser - TE/AMP 282766-1 - female housing, Junior Power Timer, new style finger-operated spring-clip
TPS CONNECTOR, 6-position
Bosch 1 287 013 004
Nissan 300ZX MAF connector
TERMINALS, SEALS, BOOTS
Mouser - TE/AMP 925595-1 - female terminal, Junior Timer 17-13ga
Mouser - TE/AMP 927845-1 - female terminal, Junior Timer 20-17ga
Mouser - TE/AMP 925596-2 - female terminal, Junior Timer 20-15ga
Mouser - TE/AMP 964273-1 - female terminal, Junior Power Timer 17-13ga
Mouser - TE/AMP 964284-1 - female terminal, Junior Power Timer 20-17ga
Mouser - TE/AMP 964280-2 - female terminal, Junior Power Timer 24-20ga
Mouser - TE/AMP 964280-1 - female terminal, Junior Power Timer 24ga
Mouser - TE/AMP 1-965982-1 - male terminal, Junior Power Timer 22-18g
Mouser - TE/AMP 1-963860-1 - male terminal, Junior Power Timer 24-20g
Mouser - TE/AMP 828905-1 - wire seal white
Mouser - TE/AMP 828904-2 - wire seal blue
Mouser - TE/AMP 880810-1 - rubber boot, 2-position
Mouser - TE/AMP 880811-2 - rubber boot, 3-position
For posterity.
Bosch 1 287 013 004
