928 Forum 1978-1995
Sponsored by: 928 Specialists
94 GTS Comes Back Strong(er)
Old 11-02-2016, 03:19 PM
Tomkat80222
Tomkat80222's Avatar
Holy (literately) crap! How is the water and oil not one big soup? So, approximately how much would this service cost?
Old 11-02-2016, 03:22 PM
safulop
safulop's Avatar
Holy crap, those heads. Anyone want to buy my S4? Probably needs new head gasket, after what I'm seeing here.
Old 11-02-2016, 03:27 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Head gasket deterioration from not driving the car and letting it sit for years and years with old, acidic coolant. I change the coolant every 2-3 years and even test the pH occasionally.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-02-2016, 03:30 PM
FredR
FredR's Avatar
A good call to pull the motor and do the heads. It is quite easy to assume there is no need but I rather feel that low mileage examples ar emore vulnerable to head gasket deterioration because they sit there idle for too long lack of circulation of the coolant possibly leads to a localised deterioration of the gasket and in some cases the top of the cylinder towers.
Having someone like Greg do the work for you must be the icing on the cake as it were. When I took on my current 928 over 10 years ago to put my late S4 motor in it, it was tempting to simply put the motor in the car and hope for the best. Fortunately I was smarter than that, instigated a tentative compression check, No 7 was duff, so we gutted the top end of the motor and dropped the sump but left the bottom end intact just like Greg did here. 10+ years on no real issues to date but the sump gasket is weeping a bit now.
To the OP hopefully you will have many happy years of motoring knowing that a very safe pair of hands has checked it over and sorted it out.
Rgds
Fred
Old 11-02-2016, 05:26 PM
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by Rob Edwards
V2, best discussion of GTS piston oil hole drilling is likely here:
https://rennlist.com/forums/928-foru...s-pistons.html
Thanks for the link and interesting read.
I was thinking they had modified the oil drain back holes from head-block-sump...never thought about pistons.
Old 11-02-2016, 08:27 PM
Jherriott
Jherriott's Avatar
Originally Posted by GregBBRD
This is how it goes when dealing with a German....who will never admit that they did anything wrong.
They will insist that the real problem is that the oil control rings are in the wrong place in relationship to the other rings due to some harmonic or frequency that they have found, previously unknown to all others. They will redesign the piston, moving the rings, a bit. The oil drain back holes will magically appear in the redesign, but will not be talked about. All parties will know what the problem was and what the solution was, but they will never talk about it. It's the German way.
greg brown
Too good!
Old 11-03-2016, 09:51 AM
Slantnose!
Slantnose!'s Avatar
Hey, saw the car in the court other day and was really looking good...had no idea, sorry had to go thru all that.
Old 11-04-2016, 11:46 AM
DaveT
DaveT's Avatar
A few more photos of the process here. Also a bit of feedback on some of the posts here. Yes, the pics of the head gaskets are scary. I guess I was lucky as the oil was pristine (no water), there were no head gasket leaks or loss of compression that I could tell, and the motor ran fine. Greg did note some concern about corrosion when he pulled the water pump, and what the heads might look like. However when the heads did come off the concern went away. While the heads did require some welding Greg never categorized the deterioration as anything but what he usually sees. This was supported by no additional costs beyond what he had estimated for normal repairs prior to pulling the heads.
I appreciate the comments and feedback as I constantly learn more about the cars.
Old 11-04-2016, 02:38 PM
Jherriott
Jherriott's Avatar
^^^ Gorgeous!
Old 11-04-2016, 03:05 PM
hlee96
hlee96's Avatar
Sure it wasn't a new engine that Greg swapped in while you were not looking?
Old 11-04-2016, 03:51 PM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,297 Likes on 493 Posts
Gorgeous indeed.
Love to see clean engine like this.
Refreshed also...
Old 11-05-2016, 05:53 AM
safulop
safulop's Avatar
I guess it'll pass smog now
Old 11-05-2016, 11:19 AM
SwayBar
SwayBar's Avatar
Beautiful work!
Did you put the stock cams back in, or did you opt for GT or S3 cams?
Old 11-06-2016, 09:55 AM
DaveT
DaveT's Avatar
The stock cams went back in. We did discuss performance modifications ranging from headers and custom exhaust to a stroker motor. In the end I wanted to keep the car original.
A few more photos showing various some underside repairs/additions. These included upper and lower ball joint boots, tie rod assemblies, sway bar drop links, shocks and dust covers, CV joint boots and new front belly pan (now both pans have the correct fasteners).
After all of the work was done Greg drove the car for about 150 miles and the result is that the car is now properly sorted. The car went back on the lift several times as minor items were addressed. His attention to detail is impressive. He even noticed that a dust cap for a brake bleeder and a holder for an ABS sensor cable were missing and replaced them.
I apologize for the rotated pics; can't figure out why these appear that way.
Old 11-07-2016, 02:57 PM
Chris Lockhart
Chris Lockhart's Avatar
Absolutely beautifully cleaned engine!!!
OK Greg, besides elbow grease what product(s) do you use on the exterior of the block to get it so clean?!?! I've got hours and hours into cleaning mine and while it looks good, it's nowhere even close to that! Wow!!
Quick Reply: 94 GTS Comes Back Strong(er)
