928 Forum 1978-1995
Sponsored by: 928 Specialists
Something jumped on the trailer...NEW! Engine pics!
Old 10-16-2016, 08:58 PM
drscottsmith
drscottsmith's Avatar
Default Something jumped on the trailer...NEW! Engine pics!
Well - I am officially a member now! Very excited - and ready to get to work.
Ended up getting what I think is a very good deal, and I could always recoup the funds as a parts car...here are the vitals:
1983 928S - 5sp.
110K showing
No history
No major interesting options other than I405 Level Control System.
Does not run - timing belt and water pump are apparently rather new - dont know though until we can verify.
New tires
Spare ECU included with car as well as several relays - electricals are apparently suspect in the no start
Engine does turn over
Valley has a lot of oil in it.
Lots of corrosion on the main power line coming from jump post.
Jump post cover is missing - I know, I know....
Brakes and clutch apparently are ok...at face value anyways (Car stops and when you drop the clutch with it rolling it engages.
No tool kit or compressor.
Time to start taking loads of pics and make a plan of attack!
Looking forward to all of the advice and help from you guys - especially those in upstate SC!
-scott
Last edited by drscottsmith; 10-17-2016 at 07:03 PM. Reason: Changed Title and added pics
Old 10-16-2016, 09:09 PM
medipedicman
medipedicman's Avatar
Congratulations Scott! I look forward to following Along on your progress.
Old 10-16-2016, 09:15 PM
Dave928S
Dave928S's Avatar
Congratulations! As posted in the VIN thread, I405 might be adjustable front shocks, which weren't fitted as standard until '84.
Old 10-16-2016, 10:01 PM
drscottsmith
Default I405
I guess I need to get under there and see. Would they be electronically adjustable? I don't see any switches out of the ordinary.
will keep you posted and it will be interesting to see if anyone else with an 83 has them.
medicpedic - followed your advice and tried to find one with a better interior as a starting point (better than the green one in Knoxville). We'll get the other gremlins sorted in due time.
thanks guys!
scott
Old 10-16-2016, 10:07 PM
skpyle
skpyle's Avatar
Alright, Scott, jump in there face first!
Contact Roger Tyson, get the Moorehouse CD's so you cab get started.
Concentrate on making it run, then go from there.
Everything you need to know is here on Rennlist, you just need to find it.
Welcome to the Tank!
Seth K. Pyle
Old 10-16-2016, 10:38 PM
hlee96
hlee96's Avatar
Congratulations! Welcome to the addiction. Love the color, is it kiln red?
Old 10-16-2016, 10:51 PM
Shawn Stanford
Shawn Stanford's Avatar
Looks pretty typical so far. The dash and pod look nice. Good luck!
Old 10-17-2016, 12:38 AM
Dave928S
Dave928S's Avatar
will keep you posted and it will be interesting to see if anyone else with an 83 has them. ......
Scott .... what I think they may be referring to is the threaded sleeves and nut on the shock absorber, to adjust ride height, which you'll see on the rear, but which weren't fitted on the front on the early cars. I didn't have them on my '82, but added later adjustable perches and collars to give front adjustment. No electrical involved.
Edit Not so sure now ... might be headlight height adjuster near the handbrake ... but strange as I405 only appears on MY83 US and California cars, and I know it's fitted to earlier cars.
Old 10-17-2016, 10:33 AM
skpyle
skpyle's Avatar
Hi Scott!
I have a house warming gift for your new 928! It is a replacement jump post cover and an original jump post cap. As a new 928 owner, someone gifted me a new jump post cover out of good will. I am paying that forward to another new 928 owner.
The jump post cover is in excellent condition. The jump post cap is in good, though very used condition. It is missing the lanyard and has a piece of the flange broken off. However, it is quite serviceable.
PM me your address and I will get it shipped to you.
Seth K. Pyle
Old 10-17-2016, 10:59 AM
drscottsmith
You are the man! I'll have to pay it forward too!
Thank you -
Scott
Old 10-17-2016, 11:14 AM
skpyle
skpyle's Avatar
Excellent!
Scott, you are quite welcome!
Seth K. Pyle
Old 10-17-2016, 01:26 PM
The Deputy
The Deputy's Avatar
Looks like a great project. Congratulation. Love the color, Kiln red I believe...good stuff. First things first, get after those rubber fuel lines under the hood and injector grommets.
Good luck!
Brian.
Old 10-17-2016, 07:06 PM
drscottsmith
Default Adding some new engine pics...
Please weigh in with the good and bad...
Thanks all!
Old 10-17-2016, 07:30 PM
G.P.
G.P.'s Avatar
If you have not disconnected the battery yet, I would do so. Then check the wiring, the positive to the jump post and the wiring at the 14 pin connector look a bit old and tired.
Sometimes it's good to point out the obvious.
Old 10-17-2016, 08:06 PM
James Bailey
James Bailey's Avatar
Originally Posted by Dave928S
Scott ....
the adjust on the fly headlights were always illegal on USA spec 928s so not that !! even federalized Euros were supposed to have the system disabled....
Quick Reply: Something jumped on the trailer...NEW! Engine pics!
