89' S4 Leaking ATF
89' S4 Leaking ATF
My Porsche is leaking atf out of what looks like a air hose fitting. Is there a cap that should be here? I could not find it in the parts catalog.
Ed
Ed
Former Vendor
Absolutely!
Missing a cap and an aluminum seal.
I don't have PET here, but if you look in group 3 (transmission) and go to the section for the automatic lines and hoses, you will find the part numbers.
928 International will have it used.....
That is the ATF fill port. It should have an octagonal cover (IIRC) over it. The fill port is oriented as such for it has a ball valve. One can fill simply with a tube/hose and a little pressure behind it. I have a hand pump that screws on my ATF bottles that works well. Even without the cover it shouldn't leak. I'd call Mark or Roger for a new one. I forget the size, but you can simply screw in a bolt with a crush ring in the interim.
13-19 is your business end. If banjo bolt 12 and 13 are identical, a M14 bolt with an appropriate crush ring may work until you have all your final pieces.
