Fabricated Rear Side Marker Gasket
Took my rear side markers off, and one of the gaskets is torn (other one is in bad shape as well). Did some searching here, and don't find any threads with gasket alternatives outside of 928 Classics item (site is down, so don't know if still available).
Anyone make one out of foam or gasket material? If so, what did you use?
Thanks!
Thanks!
I talked with Jim about 8 months ago and he referred me to Grainger, IIRC. There is a certain size rubber/silicone "band/gasket" that you can order that works for very little money. Not perfect but does the job. I just don't remember the mm/inch size and thickness but if he catches this thread, I'm sure he'll tell us.
Paul, I don't publicly share proprietary information, especially on a forum of which I'm not a sponsor.
As a courtesy, enthusiast to enthusiast, 928 Classics (classicS, Dave) doesn't have any in stock, with no planned ETA.
Sorry all, time for some grassroots engineering.
Cottage Industry Sponsor
I used to use Loctite 454 to glue the ends together.
Occasionally I would get a very mad customer who assumed that he'd get a seamless gasket, and would badmouth me on whatever forum he found me. Eventually, I stopped offering the seals separately - Nobody complained when they were included with the clear side marker unit.
