928 Forum 1978-1995
Sponsored by: 928 Specialists
odometer gear
Old 09-06-2016, 10:27 AM
Wisconsin Joe
Wisconsin Joe's Avatar
Ask OTR18Wheeler (Farris). He had the same problem a little while back.
Old 09-06-2016, 11:35 AM
linderpat
linderpat's Avatar
Received 2,419 Likes on 1,312 Posts
Originally Posted by murray928
Called - not these folks; they do not do anything from the electronic side, older mechanical speedos only. They recommended a guy at West Valley Auto Instruments on the West coast. I have a call into Specialty Gauges (Corey).
Old 09-06-2016, 12:34 PM
BIMMERMIKE
BIMMERMIKE's Avatar
Originally Posted by linderpat
Pictures and details are in these threads (there are more threads on this - lots written about it altho none had answered my original question here):
https://rennlist.com/forums/928-foru...r-no-work.html
https://rennlist.com/forums/928-foru...r-failure.html
Old 09-18-2016, 04:45 PM
linderpat
linderpat's Avatar
Speedo back and in, and a new odo gear just for grins (old was not broken, but why not replace while it's all out). Sent it to Specialty Gauges, Corey Shepherd per above recommendation, and the work was good, fast and reasonable. Did the whole pod and cluster R&R while I was at it. Everything is good, and lights are nice and bright. Thanks to Dwayne for his excellent write up (and it was great assistance with pod reinstall), and Matt for the referral to Corey
Old 09-19-2016, 01:29 PM
kawi825
kawi825's Avatar
Great news Ed.
Old 02-06-2017, 03:10 PM
Randy V
Randy V's Avatar
Mystery solved. Took everything apart, and you can see the fried capacitor (or whatever it is). Not sure what caused it, but I am doing a full R&R on the instrument cluster, including the film. Will not solder though, as everything looks very good on the film at the rivets and elsewhere. Also, as another data point, my odo gear is not broken and does not feel brittle.
Here's the damage:
Where is that board located?
Old 02-06-2017, 04:58 PM
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
Follow this link https://rennlist.com/forums/928-foru...resist-er.html
For more info.
The board is mounted behind the odometer assembly.
Old 02-06-2017, 05:07 PM
OTR18WHEELER
For more info.
Old 02-06-2017, 10:17 PM
linderpat
linderpat's Avatar
Correct, right behind the odo. I just sent my whole unit in, and had them redo the odo gear as a WYAIT. All in about $125 plus shipping. They repaired the board, god for another 25 years.
Quick Reply: odometer gear
