tire recommendations
The GTS rears are 9 inch and can handle a 275 section quite nicely just as Alan says.
Running a 928 with a 7.5 inch rear is a complete waste of time in my [hopefully] humble opinion- sorry to say. With a 17 inch wheel the minimum rear section you should be contemplating is a 255 section and if you use a 235 up front then use a 265 on the rear and then you need rims that can carry such thus the need for a 9 inch rim on the rear.
That you can fit a 235 is a fact but a very poor compromise I would say but then I am not totally sure what the stock fitment on your model is other than the earlier models ran with a 225 on the rear so in that regard 235 would be an upgrade.
I run with a 265 up front and 295 on the rear so please excuse where I am coming from, but if you had a 255 on the rear [or wider] you would not regret it- it probably all depends on how you like to drive and budget of course.
I am a long term Michelin user but my last set of rubber- Continental- lasted better in our heat than Michelin and were just as good in my opinion- ironically I can get neither out here in my sizes at the moment.
Good luck/rgds
Fred
Chronic Tool Dropper
I recently replaced the aging (but not worn out...) PS2's with Pilot Sport AS-3's and it's a good choice so far. They are quiet, with street handling and ride easily comparable with the summer-only PS2's. I've ridden in several cars with other tires and like the quiet, handling and ride quality that the Michelins deliver. Hopefully I'll get some miles on them in next five or six years to justify replacement due to wear rather than based on age alone.
Ed,
Good luck/rgds
Fred
Good luck/rgds
Fred
