ATF Filler Port Hydraulic Quick Connect Manufacturers & Part Numbers
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
After digging through the archives, I am trying to source what could be rooster teeth in the states, but plentiful in Europe. There are multiple threads on the ATF Filler port and hydraulic quick connect couplers, but I have only found one manufacturer listed:
Rectus Type 26 with 6mm hosetail
However, this can't be the only supplier of this coupler. A member from Finland had posted a 12mm quick coupling also on this board, and in his FAQ website, but there was no part number listed. I tried tracking down the manufacturer, but I can't read Finnish.
I am creating this thread to help those out there source this hydraulic quick connect who fill up their auto transaxles in their own garage like me. I am tired of twisting a cap off next to hot components to fill up the reservoir.
If anyone is familiar with any other manufacturers and part numbers for this quick connect, please post here as well as a link for purchase if you are able to identify one.
So far the specifications from the factory WSM are as follows:
Note: DN 7,2 I assume is the inner diameter of 7.2mm for the quick connect?
Not sure if the original supplier, Mader is still in business in Germany...
Only available in Europe - maybe some of our Euro members will chime in and buy one for you.
The coupler is a standard metric quick coupler. I can dig out my receipt tonight. You really don't have to have the coupler to use the quick-fill connector. You can simply push your fluid pump outlet hose over the end of the male connector and pump the fluid in. I use a modified 2 gallon garden sprayer when doing a full fluid change but for topping up between changes I use one of the cheap hand- operated bottle pumps sold in most auto parts stores. The vinyl discharge hose pushes easily but securely onto the male quick connect.
Mike
Mike
Maybe try reaching out to Arnoud. I bought mine from him 3 years ago. I just looked at this old thread and then searched Amazon and e-bay for "Biltema 17-248" but no results.
https://rennlist.com/forums/928-foru...id-help-5.html
Hi again just done a search on Rennlist auto box filling and came up with you need a Rectus coupler typ 26 there on Ebay UK 250786852885 £13 including P+P , i think local hydraulic supplyer to me will be better priced to me.
I bought from Esska in Hamburg, part number 27053
https://www.esska-tech.co.uk/esska_e...05xx_6000.html
