Head resurfaced - before and after
#31
Which plastigauge version should I use?
Anybody know the clearance spec for the cam journals?
Thanks.
#32
Captain Obvious
Super User
Super User
Yes, for the 91 heads.
Allied Motor Parts East Point GA.
I even spoke to the machinist that did all that and the welding. Each machinist has there own metal stamp they use to indicate the heads they worked in.
In my mind very professionally run. I asked about bead blasting and they said it was one of their steps in the process that includes a thorough cleaning of the heads. I also asked if they have ever had any returns due to beads material left behind and they said no. I trust them.
Putting the hard on a glass and rocking it does absolutely nothing. If you want to measure the heads, either take it to someone that knows how to do this or get someone to show you how to do it. I would never blindly trust anyone unless I can actually check their work.
#33
Basic Site Sponsor
Basic Site Sponsor
Regardless, study the oil galley drilling in the heads, carefully. There are a bunch of drillings that end in a dead end, past the intersecting drilling.
Impossible to blow the oil and stuck beads out of a dead end....you can soak and blow for a week and not get it all out. The plugs must be pulled, the oil galleys cleaned, and new plugs installed, if the heads got near a bead blasting cabinet.
If you are lucky, there's just a tiny amount, but even a very tiny amount will ruin an engine.
Like I said, instead of being pissed that I might know a bit more than either you or your machinist, just say: "Wow, thanks for the heads up."
#34
If you didn't remove the oil pressure check valves before sending the heads, removing them now will give you a quick visual of the trapped beads in the oil galleys.
No sign of glass beads. But there were fine bits of metal attached to the ball. Took a q-tip to the intersecting galley. No busted glass.
Here's the oil pressure check valve.
#35
Second check valve
I think the spring needs to be replaced. The o-ring is half gone and the reset turned to dust.
These Heads are from a 187ik engine.
#36
I have plastigauge. They are .025 to .076 mm and .051 to .152 mm clearance ranges. From what I have on the instructions and what I've seen in youtube videos I place the plastigage perpendicular to the cam cap, tighten to torque specs, remove the cap and measure the width of the crushed plastigage with the ruler on the plastigauge envelope.
Thanks.
Thanks.
Hopefully those more experienced than I will correct any misdirections I may have given here.
#37
Basic Site Sponsor
Basic Site Sponsor
Kevin, the oil in normal running is filtered long before it gets to those check valves and you will never see metal there. All of that large metal debris came from?
The machine shop.
Take the valve springs and valves out. Pull the end plugs. Re-clean the heads and the oil passages with long brushes. Re-assemble with new oil galley plugs.
I remove the check valves, before sending heads to the machine shop, so the ***** and springs don't get damaged like yours. The machine shop removes and replaces the oil galley plugs on their own.....the replacement plugs are the very last thing to be installed, before the heads are put in the clean bags.
I've "redone" more than a couple of engines because of this very issue....with really sad clients reaching into their wallets the second time, for the same job.
Believe it or not, I'm not just here busting your chops....I'm only trying to help.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#38
Are you referring to the big plug (appears to be new) or the two small ones?
#40
Basic Site Sponsor
Basic Site Sponsor
Go down to Harbor Freight and see if they have a small slide hammer with a screw in point (mine is Snap Off, but I'm guessing HF will have something similar). Drill a hole in each plug and remove them with the slide hammer.
Clean these passages with a long appropriate brush. Be aware that all the oil galleys to the liters are drilled perpendicular to these passages....so there is a lot of passages to clean.
Next set of heads, pull the oil check valve and the plugs before they leave your hands. Allow them to do their work, reminding them to rinse and blow out the oil galleys before they assemble. When the heads come back, you can put in the plugs, a new O-ring on the check valve cap, and be done.
#41
I know it really seems invasive Kevin - but I have done this on several sets of heads myself. Getting those galley's clean is a very educational moment, at least for me.
I drill them and then put a slide hammer over a small bolt and thread the bolt in. like 3 minutes a plug.
Then you just need to make sure you get the right parts for putting the plugs back in.
#42
And I use this relatively stiff rod and push little pieces of paper towel through, while spraying brake cleen into the oil holes at each cam journal.
I just can't risk having an engine go bad in 30 minutes for a detail like this after it takes me 5 years to get engines back into cars.
#44
Basic Site Sponsor
Basic Site Sponsor
"The devil is in the details".
Look at Kevin's picture and try to imagine that metal on those check ***** going to the tiny check valves in the lifters or to the aluminum bores for the cam journals in the heads....because that is where it is going to go, in the first few seconds of running.
Instant, complete junk.
The plugs you need are N011918.1.
I do so much of this stuff that I order them 100 at a time. I'd guessing Roger will have them.
#45
Captain Obvious
Super User
Super User
The cleaning of the oil gallies should have been the machine shops responsibility. Instead of making the heads look clean on the outside (painting them), they should have spent the time cleaning the inside. Worst part is that until Greg posted, Kevin didn't beleive me and more than likely would have dismissed my post and installed the heads as is.
