928 Forum 1978-1995
Sponsored by: 928 Specialists
Electric Supercharger/Super Bilge Blower???
Old 08-02-2005, 01:01 PM
  #61
Imo000
Captain Obvious
Super User
Imo000's Avatar
The e-Ram has been debated many times over the years on here. If I remember correctly, the total dyno gains are in the 5~7hp per unit. The two would add around 10~15hp to the 928.
27hp/eRam is a little too optimistic.
The problem with this technology is the limitation of the amount of air it can push. The demo video is impressive to look at. However the volume of boosted air is just not enough to make it a real supercharger of any kind.
If you ever have a chance to put your hand infront of a SC while the engine is revved up, you'll see what I mean about volume requirements.
Old 08-02-2005, 01:02 PM
  #62
James-man
James-man's Avatar
Cool - they updated the website!
Old 08-02-2005, 01:03 PM
  #63
Herr-Kuhn
Herr-Kuhn's Avatar
It is not forced induction, just a set of fans!
Old 08-02-2005, 01:05 PM
  #64
Fishy928S4
Fishy928S4's Avatar
IMO,
It looks liek they have two different kinds. The regular one that puts out a few ponies each at 1 psi and then the "super" one that's 1.7 psi each which puts out more.
Old 08-02-2005, 01:08 PM
  #65
chaadster
chaadster's Avatar
Originally Posted by Herr-Kuhn
That is hogwash there is no way that device can flow enough mass air to make the difference worth the time and money.
Ultimately, of course, whether an e-ram is "worth the time and money" is a personal decision, but not so whether it makes a difference (peep the dyno sheet on an '87 s4, man):
http://www.electricsupercharger.com/...928S4_dyno.JPG
I guess the hyper-paranoid-conspiracy-cynic might suggest the dyno sheets are doctored-if not totally manufactured- but the e-ram guarantee and return policy seems pretty reasonable.
Old 08-02-2005, 01:09 PM
  #66
Imo000
Captain Obvious
Super User
Imo000's Avatar
Fishy,
Can each super eRam create 1.7lb of boost on a 928 at WOT? That's alot fo air to push for a fan.
Old 08-02-2005, 01:13 PM
  #67
chaadster
chaadster's Avatar
Maybe I'm defining "forced induction" incorrectly, but the idea is to defeat the airbox vacuum and increase the density of air into the engine. It is forcing the air being inducted into the engine, so you see my confusion, Herr-Kuhn...
Old 08-02-2005, 01:15 PM
  #68
chaadster
chaadster's Avatar
Originally Posted by Imo000
Fishy,
Nothing like second-hand info! Why don't you take the time to read their website? It's easy: link is provided in the first post of the thread.
Old 08-02-2005, 01:17 PM
  #69
Imo000
Captain Obvious
Super User
Imo000's Avatar
Chad,
Air VOLUME is the key when it comes to forced induction.
If you really want to SC your car for cheap, buy a SC and make the plumbing and bracket yourself. I did mine for under $1000. Although it's not as sophisticated as all the other kit’s on the market, but for the little money I spent it’s a real bargain. It makes around 6-7lb of boost and the difference (approx. 100hp) is certainly noticeable even without a dyno.
Old 08-02-2005, 01:18 PM
  #70
Ketchmi
Ketchmi's Avatar
We have a customer that decided to try them out despite our objection. He put two in series and connected them to his MAF. His best dyno without and with varied by 3hp. I cannot say for sure if the fans developed any horsepower or not. His ***-o-meter said that they helped a little bit, disproven by the dyno.
On the other hand, there is an electric supercharger that shows some promise.
http://www.boosthead.com/home.php
If you see what the electrical requirements are for his systems, you will understand how these fans will not provide much, if anything at all. The Thomas Knight big boy will provide up to 8psi on a 3L engine but requires it's own electrical system with multiple batteries and a 200 amp alternator. Maximum time on boost, 15 seconds. Efficient? NO. Fun to play with, could be.
Old 08-02-2005, 01:24 PM
  #71
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,168 Likes on 1,225 Posts
Just use a 1/4 mile long extension cord at the strip
Old 08-02-2005, 01:29 PM
  #72
chaadster
chaadster's Avatar
Chad,
It's Chaad....
And I don't care to SC my car for cheap, I just want to discuss the merits and downsides of the e-ram. A lot of folks shouting "Snake Oil!" without knowing the facts and claims of the device are really annoying.
There is no doubt that the e-rams will not produce the power gains of a belt-driven supercharger, but for some applications, could the e-ram be an effective addition?
Because it only runs at WOT, it seems a better racing app than street device.
Old 08-02-2005, 01:34 PM
  #73
Ketchmi
Ketchmi's Avatar
Uh Chaad...
I just wrote about a 3hp (gain) difference with the E-ram on a dyno. Is it worth it? Was it just the difference in the car temp or dyno? Unproven but it does prove that it's not seeing any useable boost. On a 928, 1psi of boost is worth in the area of 20+rwhp, where is it at?
Old 08-02-2005, 01:39 PM
  #74
chaadster
chaadster's Avatar
Ketchmi,
Why did he run them in series? E-ram does not suggest or recommend that setup for our cars (or any that I'm aware of). Did he try them in parallel, and with what results?
Old 08-02-2005, 01:44 PM
  #75
chaadster
chaadster's Avatar
Uh Chaad...
I'm not promoting the e-ram here, but I am curious to know if it works, and your experiences are just what I'm looking for. I do want to know about the irregular setup on the car you saw, though. That might have been the answer to your question...
Quick Reply: Electric Supercharger/Super Bilge Blower???
