Rear suspension pins - ugh
Rear suspension pins - Solved
Finally got around to putting the Konis on my 87. Removal was fairly easy, and the threaded rings came off without too much trouble.
But damn those pins are a bitch to get back in when your car is only on jack stands. I had to quit before I got the big hammer out.
I'm thinking I might try removing the callipers and rotors so I can work the pin in from the front. I have searched and it seems that might be easier.
I also read that loosening the three mounting nuts may help align it as well.
Any other tips or tricks?
The conical washers kept dropping out as I was trying to wiggle everything into alignment. I will try some thick grease on those to hold them in place. But I think I may just pull the brakes and insert the pin from the front, at least then one of conical washers is not going anywhere, once the pin is partially in.
Patience...patience...once you get the 'feel' its a 60 second job to tap em in nice and gently.
Ive always done them from the rear..no issues...i only slide the washers in..once the pin gets far enough to hold them there.
Yes it is a bit tricky - I found it helps by feeding a dowel of some kind from the other side of the bolt to retain those washers and then as you feed the bolt back in it pushes the dowel out. On one side I used both pins and when I fitted the other side I then used a long extension bar from my socket set.
As Jeff says just a question of patience.
The second one went in much easier that the first one I reassembled.
Rgds
Fred
Rgds
Fred
This made things simple and easy. I cut a piece from a scrap pivot pin, tapered one end and bored a hole in the other end to clear the threads of the pin to be installed.
Sorry for the picture quality.
i sometimes use a large screwdriver to "move things around " as i push the pin through all the holes and washers.
this bored out and threaded pin is a nice idea .
That horizontal support bolt for crossmember is also much easier with a taper. I wish I had your metalworking skills and tools to do either!
For the suspension pins I used long extension to help align things from other side, and pushed pin through one hole/washer at a time. It could be really frustrating at times, other times it's been quick and easy. One of those jobs when taking a break works magic!
Team Owner
make sure you have the lower sway bar link removed from each LCA
Chronic Tool Dropper
My toolbox includes several sizes of roll-head bars and other alignment bars and pins. . Tapered on one end so it works well for piloting pins like this, a slipper -foot on other end for odd-angle prying tasks. Medium one for the suspension pins, small one is perfect for getting those braces by the motor mounts lined up in advance of the bolts.
