928 Forum 1978-1995
Sponsored by: 928 Specialists
Spot the problem
Old Apr 24, 2016 | 04:59 PM
bran3b's Avatar
bran3b
Default Spot the problem
I finally got around to pulling the transmission in #227. It had to come out because it grinds and just plain sounds/feels bad. I was a little disappointed when I popped the cover and everything looked great. After sitting back and thinking about other possible causes I checked everything more closely. see the 2nd picture, sorry for the poor phone focus.
File Type: jpg
File Type: jpg
Old Apr 24, 2016 | 05:43 PM
Lizard928's Avatar
Lizard928
Yup, fixed others like that. Not fun.
Old Apr 24, 2016 | 05:58 PM
FredR's Avatar
FredR
Is that the weak synchros in the early boxes that go south?
If so is there a long term fix for it?
Old Apr 24, 2016 | 06:22 PM
bran3b's Avatar
bran3b
I'll dig into this box someday and do a proper rebuild. the rest of the insides look good, so someone really beat up on this reverse gear. Luckily I have a spare box almost ready to go in, will order a few seals and in it goes.
Old Apr 24, 2016 | 08:36 PM
jeff spahn's Avatar
jeff spahn
Just skip that tooth. You'll be fine
Old Apr 24, 2016 | 10:43 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
That's reverse gear....no synchro in reverse.
Make sure the clutch is fully releasing. That is generally what beats up reverse gears and the synchros.
By the looks of the metal glitter sitting on top of the **** rods, there's a bearing disintegrating, too. Probably the input ball bearing.
Old Apr 24, 2016 | 11:07 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Greg is correct (as always) on the transmission being discussed - but just for completion, starting in '85 reverse is synchronized...
Old Apr 25, 2016 | 08:36 PM
bran3b's Avatar
bran3b
I agree that Greg is correct, the clutch was not releasing cleanly. I just replaced the clutch, throwout bearing and pilot bearing hoping that it would clear up the issues that the car was having, and it fixed a lot, but nothing could cover this up.
