928 Forum 1978-1995
Sponsored by: 928 Specialists
My '78 US #412 and all things '78 and '79 related
Old 03-30-2016, 01:42 PM
  #31
LT Texan
LT Texan's Avatar
Looks like the Mercury/Contour fan install. Is there a fan controller?
Old 03-30-2016, 03:22 PM
  #32
Jadz928
Jadz928's Avatar
Now I understand why you are having charging issues. If that dual fan was installed w/o upgrading the alternator, you'll have a problem - esp if both fans come on at the same time (not dual-stage).
The stock alt is marginal to begin with, so you'll need to consider at least a 90 Amp alternator. And/or ditch the electric fan setup and return to stock.
Add-on fans and other things you've mentioned are bandaids for a poorly working, undiagnosed cooling system. Start with getting an IR thermometer and getting some readings in front and behind the thermostat (inlet & outlet hose). Also take readings on the radiator, top and bottom. My guess as the bottom cores of your radiator are plugged, so it will read cooler there. And my guess is there was a leak and some nasty stop-leak was added which made things worse (and leak more).
Get prepared to replace your radiator (which I assume is original).
Old 03-30-2016, 09:22 PM
  #33
The Deputy
The Deputy's Avatar
Originally Posted by VanD
Some of my earlier cars have no lights in the panels....
If I ever get a chance to see your 78's...they will have no radios in the dashes...too...evil lol.
Cooling issue...
I agree with Jim...find the true problem. The cooling system is more than proficient at doing its job, when in proper working order. Compensating for failing or obstructed parts is not a repair.
Brian.
Old 03-30-2016, 09:50 PM
  #34
karl ruiter
karl ruiter's Avatar
Here is a thought about your fuel lines. There a number of rubber hoses in addition to the hard lines, but only one is in the engine compartment and on the high pressure (input side). If you are watching your funds, replace only that one first and just inspect the others. You can either go stock (if available) or GB.
Old 03-31-2016, 06:14 AM
  #35
crushingday
crushingday's Avatar
Thank you very much Karl. can you tell me where this line is specifically. I really appreciate your help. If only one is what is most important to address immediately , I may go with a GB one and do the others later.
Old 03-31-2016, 06:29 AM
  #36
The Deputy
The Deputy's Avatar
There are two rubber fuel lines that run between the inner fender, passenger side, and exhaust manifold. These are the two that turn the car to toast if leaking.
Be very, very careful undoing the lines, they can be a real bastard and you do not want to ruin the two steel hard lines on the engine-end of things, for they are very, very hard to find in good shape, or the steel lines under the car for that matter. Start soaking them down with Blaster or WD40 Extreme...for about a month before even starting on the removal process.
Personally, I'd do them both while you are under there. Both lines run next to one another...and once one is removed, it gives you a bit more room for working the wrenches on the next one. Plus, if you are going to get gas all over yourself removing one...why wait to do it again later...for the other? Buy a set of quality line wrenches, 17mm and 19mm (if I remember correctly, so check first), no cheapy, off the wall crap or you will be very, very sorry.
Good luck,
Brian.
Old 03-31-2016, 03:38 PM
  #37
karl ruiter
The two rubber lines in the engine compartment are under the coolant water reservoir. You want the one that comes from the pump, not the one that returns to the tank. You can figure out which one this is by tracing it back to the drivers side rear wheel well. The vent line also goes there, but at the front it just has a plain rubber hose with a hose clamp. You could also find it by tracing back from the inlet port of the fuel distributor. Or just call up GB and order the high pressure side hose. For sure he should know which one that is.
Old 03-31-2016, 11:20 PM
  #38
Rammer356
Rammer356's Avatar
Car looks amazing. Please post some pics of the interior when you have a chance...
Old 04-01-2016, 02:19 AM
  #39
crushingday
Old 04-01-2016, 02:49 AM
  #40
granprixweiss928
granprixweiss928's Avatar
Love the dark green interior. Nice buy.
Old 04-04-2016, 02:33 AM
  #41
crushingday
I do not see a fan controller. not sure where to look though.
Old 07-10-2016, 08:54 AM
  #42
Oldewoodupes
Oldewoodupes's Avatar
Did you figure out the buzzing from the fuse panel at startup? mine does the same thing. Just got mine, haven't had a chance to dig in yet, can't wait.
Old 07-10-2016, 12:44 PM
  #43
Jim Chambers
Jim Chambers's Avatar
I think the buzzer goes with the fasten seat belt reminder light.
My '78 0917 has a **** with a circular arrow where the dash crest is on 412. What does the **** control? Can't find a reference to it in my owner's manual.
Old 07-10-2016, 02:49 PM
  #44
crushingday
Jim is right it was the seatbelt warning buzzer. I have not seen or heard of this ****? I am not all knowing however. Do you have a picture of it?
Old 07-10-2016, 03:01 PM
  #45
crushingday
..and more pictures 'cause everybody loves pictures
Quick Reply: My '78 US #412 and all things '78 and '79 related
