Installing a clutch master in 10 minutes WITHOUT cutting a hole in the fender
Administrator - "Tyson"
Hindsight I'm glad this one was leaking otherwise I would have been dying with trying to get the clutch bubbles out.
Sorry Doc, there is no "right way" when talking about cutting a hole in the car to perform a regular maintenance job that can easily be performed without.
Justifying the correct way to cut the hole is like saying there is a preferred way to catch herpes.
If I find myself inspecting a 5-speed 928 with signs of a fender hole, I'm going to assume the rest of the car has been maintained along the same lines, like this car:
http://www.************.com/content....-997-GT3-build
I remember when Greg called me because of this thread:
https://rennlist.com/forums/928-foru...ml#post7036661
He still didn't believe this was a thing people did...... he wanted me to let him in on the "joke".
What about getting some all-thread rod and putting it in the two threaded holes. It will stay in place as the edges of the thread should catch the firewall. Go inside put a nut on one to pull it in place. Remove the second one to install the bolt, then remove the first one to install the bolt.
Been a while since I was in that area of any of my cars. The 83 race car will need this for sure.
Shameful Thread Killer
Note: I'm joking (as I was in my original post). The performance benefits from cutting a hole in the fender is rivaled only by one of those electric turbochargers for sale on the internet. But, as long as you're coming up with justifications for cutting a hole in the fender, you might as well throw in performance advantages, too.
The justification was saving 5-6 hours of time to replace the blue hose without any loss of strength, or affect to the cosmetics of the car. The flap cut took 6 minutes, and the blue hose install took 4 minutes, then returning the flap and securing it with a sealant took another 5 minutes. Of course, some folks would R&R the engine before using the hole/flap method. Meh - that's why I live in the US.
Supercharged
Great writeup!
For reference, (I didn't do it, but man did it make it easy to access the master), this is what it looks like if you cut a hole in the fender.
