1986 928 Oil Change DIY
if "everything "is that the 928 takes more than 7.5 quarts, then yes, i know" everything".
oh, and if using a oil pan, and while its pouring out, you swap out the oil pan for another..............and by thinking thats a joke and pretty lame, and thats "everything" too? then, yes, i know a lot more than you!!
you are a funny guy Glen.... do as i do... prove it then. show me a video of you draing the oil and putting 7.5 quarts in and then show the dipstick. its a joke, right??
Under the Lift
Whether you use a big bucket or a couple of small buckets to catch the oil is not too important. And, yes, I thought the 7.5 qt minimum fill was odd, unless perhaps you don't change the filter or the car is jacked up only on the side where the drain plug is located. Regardless, you add oil until it registers correctly on the dipstick. There are lots of fine points on the process, only a few of which are critical. So, Mark's not wrong, but it's hardly worth arguing.
Did the oil change
So I tackled the oil change over the weekend. I had noticed that there was a small leak (maybe a teaspoon on the ground after a few days). It appeared that even though the oil pan, wires & transmission had oil on them, the oil seemed to be coming from around the oil filter itself. I cleaned up all of the components with WD40/Brass brush & I think the culprit was simply that the oil filter was slightly loose. I've driven it for two days & put almost 50 miles on the car & everything is dry as a bone since then. Love when a well planned idea comes to fruition. LOL
Oh and by the way, I should have taken the advice about the freakin' amount of oil that comes out of the beasts. I had my handy dandy Harbor Freight oil catch with the big funnel catch. The stream changed direction as I turned around to grab a tool & 2 quarts ended up on the floor/tarp. Took me an extra 45 minutes of clean up time. Live and learn. Won't make that mistake again.
Gosh, Mark, the attitude is really off-putting but I'll respond with facts, anyways.
The 928, as you may know, came with three distinct engines and three distinct oil cooling schemes. The oil cooling systems include having no oil cooler at all.
Factor in additional variations in how much oil drains out (How's it jacked? Is it hot?) and oil filter volume and there is absolutely no single fill volume that'll work for all cars.
In my original post that you disparaged, I noted that the cars will take from 7.5 to 9 quarts. I stand by that. Even more, I stand by filling it adequately (7qts) for a brief, stationary test and then topping it off afterwards.
Kind regards!
have fun with your oil pressure light coming on at a DE with mobil 1. dont risk it, almost any oil but that (vavoline racinig 20-50 is bad too) safe bet is redline or kendal
glen, thats cave man oil change (really swapping oil catchers?) my god, just get the 10 quart from pep boys or your local auto store
there is NO 928 that takes 7.5 quarts , unless you drain it with the driver side up in the air
it takes 9 quarts if drained the proper way. the proper way is on the lift, or lifting the driver side, drain, lower the car and wait for a few mins,and then lift back up and put the plug back in. pull oil filter and replace and fill it half way before reinstalling it. keeps the engine from going dry until the oil is pumped and has filled the filter.
Team Owner
for your 86,
put 8 qts in, fill the filter first.
Run it for a few mins then shut it off,
wait 5 mins check the oil level,
You will probably need to add more,
best to have the level 1/3 under topped off ,
as when the oil gets hot the level rises
