87 Intake manifold changes (early vs late)?
I did some searches and not finding it.....
Isn't there some difference between the early 87 and later 87+ intake manifolds? Something to do with spacers and how they mount to the head and fuel rail??
Early ones have a rubber isolator to mount the fuel rail which is best replaced with an aluminum spacer. Late fuel rails are solidly mounted.
Late manifolds have cast ribs around the flappy. (So the valve doesn't freeze?)
I seem to remember being advised that the GTS inlet manifolds are slightly different to the S4 and although they are physically interchangeable for whatever reason it is not optimal to do so.
If anyone knows what the differences are I would be interested given I have a spare early GTS manifold and cam covers I would like to refurbish/use on my S4 motor [or a new build GTS?].
Rgds
Fred
Rgds
Fred
Late fuel rails are solidly mounted - same fuel rails (AFAIK) but the boss was made higher on the later manifold.
Hacker,
It is the Fuel Rails that have different mounting heights, not the intakes, ... see my post #13 in this thread from 6 years ago. https://rennlist.com/forums/928-foru...-question.html
Here is a pic from that thread....
"This will help for everyone to easily tell the difference between the early and late style fuel rails. As you can see in the photo early version has "squared" mounting tabs/ears and the late style has "rounded" mounting tabs/ears. Sorry for the fuzzy pic."
Cheers,
Dave
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Awesome, thanks guys. That is exactly what I was thinking, just had the incorrect part on the mind
I'm asking because I'm heading over to Turbo Todd's later today to go over some project details. I'm going to pick through his parts bin to come away with every part one would want to powerder coat on an S4 so I don't have to disassemble mine.
When I do this refresh, it appears the best route is also grab some later fuel rails.
